- Thayer
- KS
National Scramble Moab 2014 - Event Trails and Vehicle Requirements/Guidelines
The following outlines the type trails that will be offered as guided day trips and the suggested vehicle requirements/guidelines for each level of these trails.
Trails/vehicles are rated for difficulty in order for you to enjoy your visit. Ratings are not meant to be a challenge.
We have broken the vehicles and trails into four distinct groups.
They are, in order of easiest to hardest, 1). Scenic, 2). Moderate, 3). Difficult, and 4). Extreme.
The trail ratings are based on the most difficult obstacle on that particular trail. Do not expect obstacles of that level all day. We have tried to match vehicle requirements with the level of trails offered. Therefore, in order to run an Extreme trail, it is STRONGLY recommended that your rig meet the requirements of the Extreme vehicle description as stated below, and so on for each class.
Scenic/Easy:
Trails are passable by stock Scramblers. Scenic, touring trail ride.
Four wheel drive required occasionally; includes highway, improved dirt, gravel, and some rock or mud.
Chances of vehicular damage are extremely low.
It is STRONGLY recommended that Scramblers in this class have the following:
Spare tire, jack, fire extinguisher, tow strap, tow points front and rear (no welded hooks), seat belts for all passengers, secured battery, first-aid kit, and cb radio recommended.
Moderate:
Intended for drivers with little or no experience driving a modified vehicle, or experienced drivers with a stock vehicle.
These trails are moderately demanding. You will encounter a wide variety of challenges, including slick rock, sand, creeks, hill climbs, and tight maneuvers.
Chances for vehicular damage are relatively low.
Spare tire, jack, fire extinguisher, tow strap, tow points front and rear (no welded hooks), seat belts for all passengers, secured battery, first-aid kit, cb radio, a minimum of a 31" tire, minimum rear posi-trac, and roll bar.
Difficult:
Not advisable for novice drivers; potentially dangerous situations; maximum ground clearance, lowest gears, and minimum tire size of 33.
You will encounter a wide variety of challenges, including slick rock, sand, creeks, hill climbs, and tight maneuvers. Vehicle damage is very likely.
Spare tire, jack, fire extinguisher, tow strap, tow points front and rear (no welded hooks), seat belts for all passengers, secured battery, first-aid kit, cb radio, a minimum of a 33" tire, one locker required (two lockers recommended), roll cage and working winch.
Extreme:
This category is reserved for the most difficult obstacles/trails and is intended for hardcore drivers with a highly modified vehicle only!
Extremely dangerous situations; maximum ground clearance, and lowest gears necessary.
Body damage, breakage, and rollovers are highly possible/probable, if not guaranteed!
Spare tire, jack, fire extinguisher, tow strap, tow points front and rear (no welded hooks), seat belts for all passengers, secured battery, first-aid kit, cb radio, a minimum of a 36" tire, two lockers required, roll cage and working winch required.
It should be noted that you should bring a rig that is in optimum operating condition. These trails WILL find the weak link in your Scrambler. If a condition exists in your Jeep that will cause an issue on the trail, please correct it prior to arriving in Moab. Additionally, bring appropriate tools, spare parts and fluids to maintain/repair your Jeep while on the trail or back in town. Moab does have a number of automotive repair facilities and parts stores but this won't help much if your rig is broke down 20 miles from town.
I was trying to think of a way to state why we have Trail and Vehicle Requirements?
I stopped when I read the following in the Easter Jeep Safari paper put out by Red Rock 4 Wheelers. IMO they were able to state `why’ better than I ever could!
“Trail Restrictions Why”
“You may wonder why we have special restrictions on some trail rides we offer. The Red Rock 4 Wheelers think long and hard about these before we put these restrictions on any trip. Trail officials contribute their ideas, backed up by actual experience with participants on the trails. Changing trail conditions (usually due to weather related events) warrant new restrictions on familiar trails. Even the National Park Service and the BLM provide Red Rock 4-Wheelers with some trail restrictions because of their requirements.
Red Rock 4-Wheeler trail officials are well aware of the Club's restrictions on their trips. They are expected to enforce them. Don't abuse the messenger when he/she asks to check on your equipment. If you are bounced from a trail for inadequate equipment, whose fault is it really? Yours.
Your first reaction to a restriction may understandably be "why can't I go?" but we hope the next reaction will be "OK, I understand" after a careful review of the whole picture. The Club has to consider the safety and enjoyment of all participants on the trips.
If a trip is constantly delayed at the obstacles by a vehicle that has to try 3, 4, or 5 times (or be towed or winched) at these obstacles, a normal six-hour trip can easily become eight or nine hours. Factor in the increased chance for breakage or accident in these situations and the trip can become a nightmare for all involved. Then what are the officials most likely to hear from the ill-equipped vehicle? "Why didn't you tell me?"
So we are telling you now, before you break something, get hurt, or before you make 20 new enemies on a trip. Look at the restrictions as trail obstacles to be surmounted. Each new item installed on your vehicle is another obstacle to be overcome so that in the end you and others will have an enjoyable trail experience.”
Scenic/Easy:
Moderate:
Difficult:
Extreme:
