B
BritScrambler
Guest
As the time draws near for our Moab National Event I thought it to be a fitting time to start to describe the main events...the trails! This will be a series of trail descriptions. Feel free to add your comments, especially those of you that are familiar with these particular trails. Better still, would be if some of you could also add your photos.
It needs to be stated that the descriptions below are a GENERAL description of the trail. Of course the exact route(s) are up to your Trail Boss(es).
The following trail descriptions are taken from the “Moab Jeep Safari” publication by the Red Rock 4-Wheelers (with a few minor modifications, mainly deleting references to EJS specifics)
Moderate:
Thursday = Strike Ravine
This trail enters an area that remains beautiful despite the marks of "range improvements" (chaining), power lines, and uranium mining. Today, grazing continues, the power lines hum, but the mines are in ruins. Four-wheeling gets better, however, as the mine roads deteriorate. The trail is about 12 miles south of Moab and between Highway 191 and the La Sal Mountains. Much of it is in and about Pole Canyon and other headwaters of Kane Springs Canyon. One badly eroded trail portion crosses a tributary canyon called Strike Ravine for the outcrop of a tilted sandstone layer that forms the base of the trail. The rocky hills and bouldery wash-bottoms make high ground clearance throughout the underside of the vehicle an important consideration. There are sneaky rocks that make it easy for vehicles to use their sheet metal panels as "paint brushes." The trail was down-rated half a notch recently because on troublesome rock on the "Big Ugly: hill was removed by someone, but use and erosion are adding new challenges. Approximate mileage: 32 total, 11 off highway.
Scenery: In addition to the views inside the rugged canyons, there are beautiful vistas of colorful rocks, forested slopes, and the snow-covered La Sal Mountains.
Road Surfaces: The easy parts of the trail are sandy dirt with enough bedrock poking through to keep the speed down. The difficult creek-bottom parts have rocks. boulders, and ledges, and the most difficult hills have large, loose rocks.
Obstacles: Two hills have loose dirt and rocks that cause poor traction. The canyon bottoms have large rocks and rock ledges that can change with every flood. Strike Ravine is ledgy and rough, with a combination of rock steps and loose dirt.
Still haven't sent in your registration??? REGISTER HERE!
Moderate:
