Hi there!. How does voltage/power get to the light switch terminals?? I know that sounds stupid, but here’s the problem. I have an ‘84 cj7. It’s been re-wired with a Summit GM wiring harness. I have switched 12v power to the ‘B1’ switch terminal. I have power from the dimmer to to the ‘H’ terminal on the switch and the lights work fine. However, there is no power to any of the other switch terminals!! I can put power to the other terminals on the switch, but then the switch gets hot! Any and all help will be greatly appreciated!!
