Tranny I.D.
This is a copy from the "stupid transmission question" post:
I had running hell trying to ID my transmission. Finally, I went to 4WD Hardware magazine. Here's what they say about the SR4 & T4:
SR4 - Aluminum case, 4 speed transmission; uses ball bearings on maindrive gear and mainshaft; the top cover has a Ford casting mark; used from 1980-81 4,6 cyl. CJ.
Casting Number on Transmission Case:
13-32-065-9XX or 13-40-065-9XX
Case Length:
9.25"
T4 - Aluminum case, 4 speed transmision; uses tapered bearings on maindrive gear and mainshaft; used from 1982-86 4,6 cyl. model CJ5, CJ-7, CJ8.
13-51-065-9XX or 13-52-065-9XX
Case Length:
9 3/16"
Hope this helps. Good Luck - Dwain
