- Aurora
- IL
The following outlines the trails we will offer as guided day trips and the vehicle requirements for each level of these trails.
Trails/vehicles are rated for difficulty in order for you to enjoy your visit. Ratings are not meant to be a challenge. We have broken the vehicles and trails into four distinct groups. They are, in order of easiest to hardest, 1). Scenic, 2). Moderate, 3). Difficult, and 4). Extreme.
The trail ratings are based on the most difficult obstacle on that particular trail. Do not expect obstacles of that level all day. We have tried to match vehicle requirements with the level of trails offered. Therefore, in order to run an Extreme trail, your rig MUST meet the requirements of the Extreme vehicle description as stated below, and so on for each class.
Scenic:
Trails are passable by stock Scramblers. Scenic, touring trail ride. Four wheel drive required occasionally; includes highway, improved dirt, gravel, and some rock or mud. Chances of vehicular damage are extremely low.
Scramblers in this class are required to have the following:
Spare tire, jack, fire extinguisher, tow strap, tow points front and rear (no welded hooks), seat belts for all passengers, secured battery, first-aid kit, and cb radio recommended.
Moderate:
Intended for drivers with little or no experience driving a modified vehicle, or experienced drivers with a stock vehicle. These trails are moderately demanding. You will encounter a wide variety of challenges, including slick rock, sand, creeks, hill climbs, and tight maneuvers. Chances for vehicular damage are relatively low.
Spare tire, jack, fire extinguisher, tow strap, tow points front and rear (no welded hooks), seat belts for all passengers, secured battery, first-aid kit, and cb radio.
Additionally, a minimum of a 31" tire, minimum rear posi-trac, and roll bar are required.
Difficult:
Not advisable for novice drivers; potentially dangerous situations; maximum ground clearance, lowest gears, and minimum tire size of 33. You will encounter a wide variety of challenges, including slick rock, sand, creeks, hill climbs, and tight maneuvers. Vehicle damage is very likely.
Additionally, a minimum of a 33" tire, one locker required (two lockers recommended), roll cage and working winch are recommended.
Extreme:
This category is reserved for the most difficult obstacles/trails and is intended for hardcore drivers with a highly modified vehicle only! Extremely dangerous situations; maximum ground clearance, and lowest gears necessary. Body damage, breakage, and rollovers are highly possible/probable, if not guaranteed!
Additionally, a minimum of a 36" tire, two lockers required, roll cage recommended, and working winch required.
It should be noted that you should bring a rig that is in optimum operating condition. These trails WILL find the weak link in your Scrambler. If a condition exists in your Jeep that will cause an issue on the trail, please correct it prior to arriving in Moab. Additionally, bring appropriate tools, spare parts and fluids to maintain/repair your Jeep while on the trail or back in town. Moab does have a number of automotive repair facilities and parts stores but this won't help much if your rig is broke down 20 miles from town.
Event Trails
Scenic:
If an interest is expressed in this we will offer guidance and/or routes for these day trips.
Moderate:
Thursday= Strike Ravine
Friday= Fins & Things
Saturday= Steel Bender
Difficult:
Thursday= Metal Masher
Friday= Hells Revenge
Saturday= Behind the Rocks
Extreme:
Thursday= Golden Spike
Friday= Moab Rim/Hells Revenge
Saturday= Pritchett Canyon
Trails are subject to changes and substitutions.
Scenic:
Moderate:
Difficult:
Extreme:
Event Trails
Scenic:
Moderate:
Difficult:
Extreme:
Having Mike and Mike or is that Mike squared watch front and rear is a nice security blanket for those playing on the big steps.
