Good eye-
Those are the TJ hood locks. They were a pain in the rear to get to fit, and when I build my tube fenders I may just make a hidden lock setup. But...they work good, and here's a quick synopsis of the install. The stock TJ locks mount at too shallow an angle, and the studs that mount to the hood are arranged horizontally. So... there are two screws that mount the tapered spacer, which holds the studs, to the locking assy. Remove these screws, and cut the spacer so it fits against the hood properly. Now drill the locking assy and tap the holes for some studs-you will notice these new studs will now go through the empty screw holes in the modified spacer, and fit the existing holes in the hood. You're now half done! Remove the plastic caps on the lock assy and with a long 1/4" drill bit drill straight down through the top of the fender. You will need a longer allen bolt fot the lock stud, and a way to lenghten the lock stud. I sleeved the stud with a piece of thinwall stainless tube, cut the tube off to the proper length to hold the hood closed tight, and filled the tube with small washers. The long allen bolt goes through the fender and bolts on the bottom. A fender washer and a lock nut on the bottom, and if you measured right-you're done!
Wow-I just re-read this and it is confusing! But if you have a set of the locks in front of you it will make sense.
As I progress with my tube fenders I will post pics and show my other lock idea.
