1x1_Speed_Craig
Simplify...
- Greeneville
- TN
Hi everyone,
Just a quick introduction. I'm new to the Jeep thing, even though I have wanted a CJ8 for about 10 years. Well, I finally got one (more in a minute).
A quick bio...I'm a Michigander, and I enjoy bicycling of all types (mountain biking, tandem mountain biking, cyclocross, road cycling, fixed gear, etc.). My username has nothing to do with Jeeps; it is a carry-over from the cycling forums I participate in. I pretty much ride single speeds exclusively...who needs all those gears? I also like canoeing, camping, etc. I have a wonderful wife and two young daughters.
On to the new-to-me CJ8? I got it from a nice (and knowledgable) guy in Ohio who is really into CJ8s. I'm not sure if he posts here or not. Mechanically, it seems to be great, but it's a candidate for a tub replacement within the next 1-2 years. That leads me to my next question...
I'm looking at the Deluxe Fiberglass Body Kit from 4WD Hardware. I'm also looking at the STC Fasttrac top, which I would mount to the steel body now (no top included with the Jeep), and it would eventually be switched over to the 'glass body. Is anyone using the Fasttrac top with a fiberglass body? What did you replace the included metal screws with for some of the mounting hardware? Any issues with installation on the fiberglass body?
Are there any other full soft tops I should consider? I ruled out the currently-available Bestop, as I don't want to install snaps in the body. I also saw the thread about the long-awaited CJ8 Supertop. Not for me, as I was instructed by 4WD Hardware that you can't order just the top; you have to order the soft doors, too. I'm getting full hard doors with the CJ8, so I need the top only.
Longer term, the Jeep will probably get a replacement frame. For now, I'm planning on getting some M.O.R.E. frame plates to reinforce the somewhat-corroded rear area of the frame. Any suggestions on frame manufacturers? I'm currently investigating Advanced Frame Works (available through 4WD Hardware) and Matkins Extreme Mandrel Bent (economy) frames. Matkins was recommended by the guy I'm buying the CJ8 from.
Sorry for the rambling...I like to talk a lot
Thanks!
Craig
Thanks!
Craig
