Is this an original late model CJ Jeep Special Equipment Warn 8274
JeepScrambler
CJ-oholic
Claflin
KS
I found a guy who says he has a "dealer installed" warn 8274 that was on his brother's Jeep. He was going to put it on his restored CJ8 but he is now selling it. He has the original Jeep mount for it but the cover on the winch doesn't say Jeep anywhere on it and he said a few guys on Pirate4x4 have told him it's for a 1982 model. Anyone know if this winch is in fact an original Jeep special equipment winch? Did all of the Special Equipment winches say "Jeep" somewhere on them? Since I am wanting to put this on one of my Scrambler's, I am just wanting to make sure that this is, or isn't a Jeep Special Equipment Winch before I try and purchase it. The number on the winch is 329054. Here are a couple of pictures of the winch.
Try calling Warn and see if they can research it. Also, years ago the owner of Central 4 Wheel Drive was working for them I think. I know he could shed some light on it or at least tell you where to research it. I know in our area the dealer installed a LOT of Warn winches on the Jeeps and many thought they were from Jeep. Good luck in the search.
As I recall, the OE Jeep Warn 8274 had Jeep printed on the tag on top of the winch gearcase.
My factory Jeep Warn M8274 winch has an original label which says Jeep Special Equipment and has the AMC logo followed by the words Manufactured by Warn Industries. Looks like yours is the same Warn 8274 winch, just not the Jeep Special Equipment version. Dave K. on this site reproduced some new replacement Jeep Special Equipment labels a while back. Hope this helps.
Jeff
Since the winch is still with the original mount, I am guessing the winch could have been a dealer installed 8274 and not a Jeep Specialty Equipment one. Did all the dealer Specialty Equipment winches have the red, white, and blue AMC logo? What other differences are there between a Jeep Specialty Equipment winch and a standard warn 8274 of the same era? Did Jeep use only one style of decals from 76-86 on their winches, or did they ever change any of the decals?
Check out this thread on the winch I picked up. The sticker is copied from the original which was on this winch and there were no red, white and blue AMC logos on it that I found. That being said some might have had them if the dealer went sticker happy.
https://www.cj-8.com/forum/showthread.php?t=21881&highlight=warn+8274
The rings on the mount are not correct and have been replaced with turn signals per the spec (they were an option).
The only real difference between the std Warn 8274 and the Jeep one was the serial number stampings. The Jeep one has only one serial stamp and no other numbers while the Warn std version has the additional number stamping at the bottom of the label area.
You can easily convert the one you have to make it a Jeep accessory unit. I can give you a serial range for stamping after you either fill or mill off the existing serial number on yours--that's if you're really a stickler for originality. Not sure if I have any extra stickers anymore but perhaps someone here that picked up two has a spare.
**Note as well that the hookup for the remote should have a metal flip cover instead of the rubber cap. All of the Warn winches of this era had the metal flip cap as I understand it so this might be a later unit .
BR, Dave.
One other question--did the guy include the frame brackets? They bolt to the frame and then the mounting plate and winch mount to them. If your order from a Warn distributor they run at about $40 or 50 /side I think. They're simple brackets and easy to fab but for the money it's not worth the hassle to make them in my opinion . . .
The guy does have all of the original mounting brackets and hardware for the winch and mounting plate. If I do end up getting the winch, I'm definitely going to want to get the correct Jeep Specialty Equipment decals, correct serial numbers, as well as a metal flip cover. Do you happen to have an extra set of decals laying around, or anyone else on this site have some they aren't using? I will have to check and see if he has to turn signals, but I'm doubting it. Thanks for all the info so far! :thumbsup:
You are correct Dennis, the roller fairlead has a galvanized finish. I ended up picking up a set of turn signals which, while not 100% correct are darn close so I went with those (free is free .. . .). nice signals by the way, someone should buy those . . .
Ref decals I'm all out and not sure if I will be making more--will let you know if nobody else has a spare.
Good luck, Dave.
I have a pair of Amber NOS turn signals that I would sell.
Hey Dennis, were those turn signals supposed to be original stock equipment for CJ's that had the 8274 installed? I have one on my '83, but I have never looked to see if my signals were obscured. By the way, does anybody know if the 8274 was ever an option for Scramblers?
Jeep SE Winches
While we're on topic of Jeep SE winches....
Is there any interest in the "Jamboree" Ramsey winch?
I have a NOS Ramsey winch mounting kit designed to be part of the Jambo CJ brushguard.
( I don't have the brushguard :( )
The CJ brushguard designed for winch is hardest Jeep SE item to find....
Not doing me any good.... might as well sell it.
That kit has the wiring harness for the turn signal lights previously pictured.
Markness, yes the turn signals came with the 8274 Warn kit.
Lots of pictures of Scramblers in brochures with 8274 on it.
Ramsey also.
...The CJ brushguard designed for winch is hardest Jeep SE item to find....
...the turn signals came with the 8274 Warn kit. ...Lots of pictures of Scramblers in brochures with 8274 on it.
I've seen a few original brochures, but have never seen a CJ picture with the 8274 installed. If you have any photographs, I'd love to see them. Additionally, could you describe the stock brushguard? Is it round tubular bar with a narrow spread that just covers the width of the winch and is approximately the same height -and chrome in finish?
This is my winch, still for sale. This is NOT a Jeep Special Equipment model, it is a 1983 model. It is a factory original Warn. In those days you could order it through the book as an option, but MOST warns put on by the dealer were directly from Warn (red labels). The Jeep catalog SE winch was black labeled and only recognized by the serial number the the black sticker around the serial number.
Similar to these days, you can buy a Hummer H2 winch from Hummer or go to the Warn dealer and get it 500.00 cheaper directly from Warn, or 4WheelParts, etc...
I have verified this with Warn. They still have all the stickers for this winch to restore it to new. AND the CHROME REMOTE FLAPPER was NOT original to this year of 8274. That was to earlier 70's model Warns. They also used different, yet similar, solenoids and you can signal with with that chrome flap cover for the remote.
THE RUBBER COVER IS CORRECT!
If you end up needing a reproduction Jeep Special Equipment Decal, let me know. I had a bunch made up.
Joe
Thanks a lot. I have you on 'speed-dial' so-to-speak if I can get this deal to go through. :thumbsup:
