Fuse
Meter
The fuse you need to check is the 5 amp one in your photo. You can pick up a meter that would work for around $10 to $20 just about any where. Sears has them on sale all the time. 12 VDC and resistance (ohms) is not hard at all once you understand a few of the basics. You can PM me and I could give you some pointers.
Cheers. The 5AMP is the IGN LPS which is supposed to be a 3 AMP I just noticed.
Hitting the road now, I will look for a meter and be in touch.
Thanks again.
Wayne.
That 5 Amp should be a 3 Amp, but that is not causing the meters to not work. If you see the numbers next to the words, the numbers are the size fuse you should be using.
If the new fuse blew right away, you have a short after the current is leaving the fuse box. If the new fuse blew after driving around a bit, you have an intermittent short when a bare wire bumps up against something. If the fuse is holding you have either....
All of the below:
A bad Temp Gauge or sender or bad path, AND
A bad fuel gauge or sender or bad path, AND
A bad oil gauge or sender or bad path, AND
A burnt light bulb on the 4wd indicator or bad switch or bad path.
OR
An open circuit.
Statistically speaking, I would guess you have an open circuit, but you can't rule out the possibility that you have multiple failures.
The circuit could be open before it gets to the meters, in which case they are not getting any power at the meter, or you have an open after the meters, in which case they are not returning to ground.
Typically the open is a bad ground wire.
Do you have any test equipment like a volt ohm meter (cheap $7.00 one would work) or an idiot light which is just a light bulb with two test leads?
4miles, I think I was typing at the same time you were, you are just faster.
I had less to type:D I do agree with you though. The fuse would not be the problem, just an indicator of a short or an open. Wayne has been working on this awhile and I believe we can get him taken care of with some help. I replied with the DARS from the fsm a while ago and a few lessons in using a meter he should be able to get it going.
Hello I'm back:
I checked the 5 AMP fuse in the IG LPS slot after I cranked the motor this morning and it was blown.
I have replaced it with a 3 AMP.
I stopped of at an auto store and got a 12V tester the one with the light inside, that was all they had.
Thanks again,
Wayne.
Wayne,
Home Depot, Lowes, Sears, Walmart, Radio Shack etc should all sell a really cheap volt ohm meter.
Please confirm that you had multiple blown fuses. The 3 Amp fuse in the bottom left was blown and the 5 (should have been 3 and is now) Amp fuse center right side was also blown. You started the car and the now 3 Amp fuse center right side blew immediately. Is that the only blown fuse now? Do I have this sequence correct?
I will be working on getting a volt meter this morning.
Yes - you are more or less right about the Sequence.
All the fuse slots now have the exact # fuse in it. All the fuses are good.
I just turned the motor over again and the 3 AMP in th IG LPS blew.
If I get time I will pull the dash out and try and get to the bulb for the 4WD indicator to see if it needs replacing?
( I guess the IG means ignition? What does the LP mean )?
Cheers.
You don't need to pull the whole dash out just to check the bulb. You can just pull the bulb and its socket holder out of the gauge. It has some clips that just hold it in place.
Wayne,
Blowing the fuse right away means that you have a short after the fuse block. There is a single red wire that leaves the fuse block, runs up into the bundle and comes out in only three places. The first place is the back of the speedometer where it powers bolt the fuel gauge and temperature gauge, the second place is the back of the oil gauge, and the third is the 4wd indicator light which is fed power by the red wire and returns to ground on the orange wire.
It is also very possible that some previous owner added wires to this circuit and the short is in the added wiring.
What you should do is unplug the red wire from the back of the speedo gauge (it pulls right off the post, no tools required) and pull the red wire off the back of the oil gauge. Remove the light bulb as well.
You have just disconnected all three leads going back to the fuse block. Put a new fuse in and start the Jeep. If the fuse still blows, the short is somewhere in the bundle or the added wiring. If the fuse does not blow, turn off the Jeep and re-connecting one gauge/light bulb at a time, starting the Jeep and checking if the fuse is blowing. This will identify which gauge/light has the short.
I can post pictures this evening if needed.
Ok thanks I will do that and let you know what happens.
I just go an Anaolog Multi Meter in case I need that?
Analog multimeter is a wonderful device. If you are not familiar with them, please post a picture of the front of your device. This will make it easier for us to tell where to turn the dial for the different tests. Please note that for the above instructions, you do not need to trace the wire through the bundle at all. Just hit the "I believe" button that the red wire originates at the fuse box and ends at those three locations.
RustCrawler:
I have taken three photos.
One is the back of the speedo. I see the red wire going into the 4WD indicator the bulb looks good and the wire looks good and it is tight.
I have a photo of the back of the oil pressure gauge. I see the red wire, it looks good and tight ( the red wire slides over the screw on the gauge)
I am not sure what you mean when you say the red wire goes to the speedo and is attached to the post and you just pull it of - WHAT DO YOU MEAN BY - POST??
In the third photo there is another red wire that was loose ( not attached to anything with a 90 degree cover/clasp- it looks like is goes over a screw or something )??
Disregard the blue pieces of tape on the wires on the speedo, I took the cluster out awhile back trying to fix this problem and I numbered everything so it went back together correctly.
I did not see a red wire coming out of the fuse box unless its behind the box.
These gauges did work untill a year ago.
No one has changed the wires recently I have owned the jeep for twenty years.
Once again thank for everything I am with you and I believe we can fix this problem.
Wayne.
Wayne,
Rustycrawlers advice was right on and a good way to find your problem. Your fuse blowing tells you have a short to ground and it could be coming from a number of places, it could be as simple as a bulb or nicked wire. He is having you do your troubleshooting in steps to pinpoint your problem. By first disconnecting the power from your gauges and removing the bulb and then starting up with a new fuse you are checking your wiring. If the fuse does not blow the wiring is good and you move to the next step and check one thing at a time by connecting it back up and starting up and checking your fuse and if that is good you go to the next one till you blow a fuse and that will tell you what is bad. I would do the fuel/temp last and hope it is not the cvr in the fuel gauge.
Wayne,
Your photos did not show up. I'm going to try posting a few pics, hopefully they come through. (edited later: Nope.)
yeah,i pulled a complete harness from the shed and took photos but can not post them yet
I guess there is a problem with up loading photos??
I have one photo that might be the answer to the puzzle, it is the red wire with th e 90 degree end that must go some where?
Quick question-
My cluster is just hanging right now from the dash
Do I need to screw it back to the dash to do the test.
When you bolt the cluster to the dash and the cluster touches the jeep body does it ground itself??
