t-5 transmission question
ataboc
Parker
CO
have loved the scrambler for years and now i'm looking at getting one. i see alot of scramblers with the t-4 4 speed tranni but i would like to have a 5 speed tranni. some scramblers came with a t-5 5 spd i hear. i have looked online to see about maybe putting a t-5 into a scrambler. question: i see alot of "mustang t-5" tranni's. is that the same tranni? thanks.
John
I think the mustang transmission is a WC 5 or world class 5 speed. I beleive it is a stronger tranny than the T5. But it'll take someone with more knowledge than me to tell you how much is involved with the swap.
I now have a NV3550 5 speed in the Scrambler. It came from an '02 wrangler. I did not do the swap myself :o but it did require a little adapting to make everything work.
A lot of people don't thiink much of the T4 or T5. I think they are considered weak or light duty transmissions.
Maybe someone who knows will chime in.
I have a busted T-5 in the back corner of the shop if that tells you anything. Busted while driving down the street. I personally wouldn't put the effort to put a jeep t-5 in. Have heard some about the mustang WC T-5 being stronger. Maybe an option there. I do believe that a T-4 can be swapped for a T-5 without modifications though.
T-4 and T-5 are basically the same case. So swapping them out is very simple. Only real difference from outside is a small bump out on the rear passenger side where 5th gear resides. Other than than they are almost identical on the outside.
The mustang 5 speed is similar to the T-5 on the inside, but there is no way to hook it to the transfer case as it is a slip yoke 2wd transmission with an integral tailhousing. Now there are ways to adapt the T-5 with some of the harder parts from the World Class T-5 in the mustang. Also there are even stronger racing upgrades.
The T-5/4 is a medium duty transmission and will generally stand up to light duty off road. It is pretty simple to rebuild and find parts for.
If a V-8 or tires much more than 31's with lots of off road are in your future. Then look for something better. If you are Daily Driving with a little fun in mind and want a 5th gear for better MPG. Then go for the T-5.
Carl
I took a T4 out and put in a T5 cause I need an overdrive since I had to use my 8 as a daily driver for several months last year. There were no modification needed and took only a couple of hours to do. I know that it is a light duty trans but I was not planning on doing any major off roading and I knew that I would soon be swapping in a 5.3/4l60e combo when the money was available. Like mentioned above, if you are running the stock engine and smaller tires, you should not have any trouble.
I've gone through two T-5s (in different CJs), and will give away the broken one in my garage to a good home. It needs third gear. Both T-5s died on the street.
When the second one went out, I got lucky and found a guy on eBay selling a World-Class T-5 that already had a Dana 300 adaptor on the back. It was a rebuilt leftover in a transmission shop that had gone out of business. The seller knew it was a WC T-5 with a Jeep adaptor on the back, but he didn't know anything else about it. It was a good deal (I think $350 shipped to AK? Maybe $450?) and had already been rebuilt, so I went for it.
Although the t-case bolted up, and the tranny bolted to the bellhousing, this was not a direct swap. The input shaft on the World-Class that I received was slightly shorter, and had a different spline count (Chevy?), and a steel front bearing retainer that was a different diameter (and was also slightly shorter). To put it in, I had to get a custom clutch disc made, be careful to not push the pilot bushing to it's extreme while installing it into the crank, and modify the throw-out lever to accept a Chevy "round" style throw-out bearing by welding on a different clip retaining system (from a Chevy lever) and welding spacers on the forward edge.
The first evening I just bolted it it, but the clutch wouldn't release all the way, so I had to pull it back out to modify the throw-out bearing lever with the spacers. I was concerned about the bearing riding too far forward and jumping off the bearing retainer, but after studying the geometry between the CJ bearing and the Chevy bearing, I decided to go for it. It worked perfect! I might have been able to simply swap over the aluminum front bearing retainer from the Jeep T-5, but I preferred the steel retainer.
Was it worth it? I'm not worried about it behind my T-5, and in the range of custom projects I've done, this was on the easy end.
I believe Advanced Adaptors was selling bolt-in WC T-5s for a while back in the '90s through 4WDH, but I don't recall seeing one in a catalog in at least 10 years, and they were spendy ($1500 or $2000). If you can get your hands on a cheap Chevy or Ford one and don't mind having a tranny shop convert it, it would be money well spent. But if the conversion/rebuild is going to cost $1500-2000, I'd just bite-the-bullet and go all the way to an AX-15 or an NV3550 and swap to the hydraulic clutch.
Carl
What Carl said.
My 81 came with a T-4 and I made the T-5 swap when Ted and I did the Dana 44 axle upgrades. I had the T-5 professionally rebuilt by a shop that builds WC T-5's, cost a pretty penny, too. They put both on the workbench and showed me where the internal differences were and what could be "upgraded" on the Jeep T-5. In the end, you can get them pretty close, just an issue of brass versus nylon/composite spacers and such. Mine is behind a stock 258 but I have Dana 44 axles, 4.10 gears, and 35" tires. Don't trail ride it much but it has been to Oak Ridge and I do take it offroad at the beach or in the snow. After 5 years transmission is still very tight and shows no signs of issues...but I wouldn't put a 401 in front of it.
I will be swapping in an automatic soon so the wife can drive it in the winter so the upgraded T5 will be for sale soon.
Richard
I have 2 CJ's. One has a t-5 and one has a t-4. The T-5 leaks and has cracks, the other no problem...just my 2 cents, but I would rather have a T-4...
With a 4 speed you probably get 2.73 gears in the axles. If you put in a 5 speed you'd need to regear to use 5th gear, especially in Colorado. All swapping in a 5 speed and swapping gears would do is get you a slower speed in 1st gear, about the most expensive way possible. Nothing wrong with 4 speeds, one less gear to shift.
