Gary R
- Arlington
- TX
Folks,
This is my poly tank that came in my -8. Does it appear to be a 20-gallon? Here's my dilemma (as also posted over in my rebuild thread):
I got my new 350 small block to start, but it will NOT pull fuel from the tank. I only put 5-gallons of fuel in the tank.
Since the fuel pump pulls fuel from a gas can but not from the tank, something fishy is going on. So I got to thinking: with only 5-gallons in the tank, IF I accidentally ordered a fuel sending unit for a 15-gallon tank, it would obviously be a LOT shorter than the sender for a 20-gallon tank. If this is the case, I'd imagine that would be the reason the sending unit won't pick-up fuel, since it's so short it's probably not reaching down to the bottom.
I've got Quadratec researching all of my past orders now, to tell me which sending unit I bought. But in the meantime, can anyone verify if my tank is a 20? It fits the factory tray that holds the tank fully, meaning it doesn't have any slop from left to right, or from top to bottom. ***UPDATE: Quadratec tells me I DID order a sending unit for a 20-gallon tank, so if this tank (below) is a 20, I can't figure out why I'm not pulling fuel !? If the tank below is a 15, the 20-gallon sending unit should definetely be deep enough to pull fuel !!??***
Maybe I need to plug the two barbs on the left (to eliminate vacuum) that used to go to the charcoal canister? Many thanks!
