$750 for a clutch?!?!
ymsmiley
Tempe
AZ
I need my rear main resealed & was just going to have a 4x4 shop do it & they're recommending I swap the clutch too. They quoted $300 for the rear main but another $400+ for an OEM replacement clutch & flywheel regrind. That's $700+ plus tax! It's been a while, about 13 years to be exact, but I remember having a Centerforce Stage 2 put in my CJ-7 at the time for around $300'ish out the door. A quick search & it looks like the CF S2 clutch is around $200 by itself these days (did I just say "these days", man I'm starting to feel old, lol).
Am I not remembering correctly or have prices just shot through the roof or what? I do know that shop rates have gone up quite a bit, but still. That said, they also quoted $200 to reseal the rear diff & pinion but that's a little more my speed & will be doing that myself. But based on those prices, I might have to do my 1st clutch job too. I'm not scared but this needs to be my daily driver for at least 6 months so it has to be done right the 1st time & too broke right now to afford any mistakes.
Question's are:
- that price ridiculous or legit?
- how big of a pain is a clutch job & any basic considerations or tips?
TYVM in advance....
The rear main seal is replaced by pulling the oil pan.Why do they want to replace the clutch too? Is it worn out?
if your clutch is slipping, it may have oil on it from the leaking rear main... if its not slipping, just drop the pan, and change the main seal..
The clutch that's in there now works perfectly fine & I'd actually be surprised if it wasn't newer, but they are telling me that since they will already be "in there" that I should replace it too & that it'd be kind of a waste if I didn't.
I just called the highly reputable 4Wheeler Supply here in AZ & they backed you guys right up on that.
Well, guess I'll have to figure it out & do it my damn self too!!! How is it possible that every fricken shop out there sux & just wants to rip you off? Grrr! I'm perfectly fine wrenching on this thing & is actually part of the reason I bought it, but jeez, was kind of hoping to be able to wait out some of this ridiculous 115 summer monsoon heat 1st. Man, that pisses me off! They know I'm laid off & struggling right now too. Bastards. Time to go get that Haynes & get this party started....
Thanks for the replies.
I had an oil leak dripping at the bottom of the bell housing when I first bought my 8. Three different people said I needed to replace the rear main seal. I put that repair off for awhile, anticipating a lot of time in the garage for me to repair.
I cleaned off the engine with a pressure washer, replaced the valve cover gasket and no more "main seal" leaks! Before you go the expense of rear main, check to see if your valve cover gasket is sealing properly.
You said a shop said your clutch was clean and working properly. More than likely, that means your transmission's input shaft seal is not leaking.
you are not "in there" when changing the rear main. you just drop the oil pan. (at least thats how i do it..)
A shop I first dealt with 9 years ago was charging $40/hr labor. Now they are up to $90. Prices climb fast at those rates.
If you haven't gone in there already, I would totally recommend doing it yourself. There are plenty of DIY sites on the internet; it was the first project I had ever done on a vehicle and I got it right the first...well second time, after shearing the first seal I bought. I'd recommend buying two, just in case. It's a weekend job, but don't expect it to seal up perfectly - if a Jeep don't leak it's out of fluids as they say, and take your time. Speaking of time, check your timing chain play while you're in there.
We're here to help.
Hello everyone & sorry that I haven't replied any sooner but I have been super busy lately. Anyway, I just wanted to follow up on the story.
Turns out, Desert Rat is in it for the money (shocker, I know) but I didn't recall them being like that before. They go by a Chilton & charge you for whatever it says, which in this case includes pulling the tranny. They are also commission based so will sell you a whole new Jeep's worth of parts if you fall for it all. In reality however, & as I've learned with your help, is that it can be done without pulling the tranny.
I just did not have the time to do this one myself as I've been working some much needed side jobs & a couple interviews for real jobs finally (keep your fingers crossed for me). But, yes, if a Jeep doesn't leak you are out of fluids & I'll be sealing it myself next time. So I called 4 Wheeler's Supply here in AZ & they quoted $165 plus parts for the rear main, almost half what Desert Rat quoted & without a new clutch & tranny pull. 4WS all but throws the Chilton out the window & quotes by the job & since they pretty much only service 4x4's & crawler's they are defiantly CJ professional's & know all the tricks of the trade & what it really takes to get to get things done. Serious trail pros. All that & no BS. Pretty refreshing to hear of a business that still has a few morals these days. I'm sure they'll still sell you that new Jeep if you need/want but at least it would be on my terms. No idea why I didn't call them in the 1st place since they were really good to me back in the day when I had my old CJ7, but its them or bust if I have anything I can't get done myself in the future.
Thanks again for the comments. It really did help me out with the sanity check that I needed. After a 10 year hiatus, I'm still working on getting my Jeep legs back under me. Take care!
$165 + parts is a deal I'd almost take for a RMS replacement. Not bad at all...
$165 seems WAY cheap. I wouldn't do it for that much for sure. Expect to also spend money on clutch linkage because it is always worn out-
Funny you mention that because I'm working on that very thing this week. Turns out the only place you can find the parts is either 4wd/Q-tec or ebay these days. Oconee O-R does have the adjuster rod for like $25 shipped, so that's helpful. I'm hoping the linkage holds up until it arrives, being light on the clutch, etc! :fingerscrossed:
