4.0L to 4.2L head swap
ScramblinScott
Now with college degree!
Kennesaw
ga
Guys,
I'm thinking about swapping a 4.0L head onto my 4.2L, any thoughts, advice, suggestions, parts lists etc????? Anybody know of a good build thread or website? Thanks....
Those sites look good and have a great parts list.
As an alternative to the epoxy/JB weld solution for the water jackets, call a local shop and see if they can weld them up for you.
Unless you have a super low mileage head you may want to get it dipped/cleaned and grind the valve seats anyway. This is what i did, and it cost me an additional $140 to get the jackets welded up and the head decked. I figured the upsides were: 1. I know I have a flat and true mount surface and 2. it will for sure never leak, where other methods might.
I bought my 85 with the 40 head on a 4.2 already installed. I initially did have some antifreeze seeping from somewhere under the exhaust manifold but never could tell where. I used some Bars Leak radiatior seal & it took care of it (at least for now) :fingerscrossed:
The performance difference between stock 258 & one with a 4.0 head is phenominal- & mine still has the Carter BBD puker on it. :evil: This thing ROCKS!!! The axle stamp claims it is is 2.72 but the gears may have been switched but I am not sure. So if it still has the 2.72 gears, then it really rocks!.
I have a Holley 2BBl & rebuild kit with mounting plate I picked up real good price but not had time to work on it. I think optimally I would prefer fuel injection since I like how it performa on my 91 YJ 4.0L. I have a line on a nice 4.0L with about 60K but no harness or computer so not sure I want to go that route. If I do, I would probably put in the complete 4.0 or build a stoker but have it fuel injected. But that is a long way off & it drives for now so I just enjoy it. I am working on the Resurection Scrambler & progress is slow but it is coming along. :woot:
I highly recommend the 4.0 head swap even if you still use it with a carb (would recommend Weber or the Ford 2150 (the ford seems to be easier to set up based on other posts I have read between the two & probably less $$). But having the ports welded will definitely make them not prone to leaking (as long as the shop welds them correctly).
:twocents:
I reused the 258 pushrods when doing the swap. The hardest part of the swap is mounting the 258 intake. Great upgrade though.
