Steering Gear and HD Tie Rod/Ends
hefavitzen
BENEFACTOR
Gold Member
Rock Hill
SC
I took my steering gear box and pump off this weekend as they have been leaking all over the place. The hoses look ok, but the rest is just old and leaking. The "ham can" return pipe is twisted and the various ports leak as well. I figure while I have those off I'll also replace the tie rods since they are the original ends as well.
But, I have been doing some research and am in need of some advise/information.
1) I see a few years ago many of you were working on upgrading to the Rugged Ridge HD steering linkage. I'd buy these in a heart beat if it is really $189 for both the right hub to pitman and the hub to hub part.
  • How do you like these parts?
  • Are you happy with them? The price seems right. (about $189)
  • Heavy duty enough and greasable?
2) I have seen lots of folks going with PSC, AGR or converting to J20 boxes or just getting a regular reman.
  • PSC - I have spoken with PSC and they say that Delphi has quit making parts so the Steering gears they still have are REALLY expensive. $539 as of today.
  • AGR SuperBox2 is currently at $399. I can't seem to raise these guys on the phone. Hope that isn't indicative of thier technical service.
  • Red-Head Steering Gear can ship me a rebuilt steering box. I spoke to Harvey, the owner and he told me the following about thier gear boxes: They put in ball bearings that are sized to each gear box, not a standard bearing for all boxes, but instead they custom fit the boxes. They will ship me a replacement with either an 18:1 worm gear (stock ratio) or a 15:1 worm gear (quicker than stock, but not variable) for $220. 1 year / unlimited milage warranty. Harvey also said that for my 350, he would recommend an AC Delco pump for a GM car or truck that is specifically a high volumn pump. My issue is that the Jeep pump return line points right at my headers, while the GM return line has a 90* bend built in. Ship my old one back to him in a US Postal flat rate box for $15 to get the $85 core charge back.
  • Blue-Top Steering Gear will rebuild my box for $175 and can rebuild with a quicker ratio if I like for an additional $80. Ryan also uses custom ball bearing sizes. He states a 24 hour turn around, of course you have to ship it to North Dakota, so you won't get it back tomorrow. Again, US Postal flat rate box - If it fits it ships for $15. If you look him up on the web, do it on Google!
  • Local parts stores have reman'ed Scrambler boxes for $150.
  • I have 31's but will go to 33's with the next tire purchase later this summer. If I can avoid doing this ever again, I would prefer it. But, i don't want to "overbuy" either. The guy at PSC says I need their HD box for $539 but it is a LOT of money; especially since I talked to him in February and I could get the slightly lesser box but not the reman Bourgeson for $400 and change. Ouch.
Any advise or information from folks who have been here before would be WAY helpful.
I did take TONS of pictures and will continue to do so and when I am done, I will be submitting a write up for how to do this and so forth. Pretty easy but lots of steps to completion...and it's messy. :)
Thanks, Jeff.
P.S. - I have been hit or miss on here as I have had my desk and computer torn down for the last month. My wife decided that "my" basement/office needed to be sheet-rocked and a proper desk put in. So...when I get done with all that I'll get set back up and be more participatory:D.
Excellent questions as my gear is pouring fluid out on the garage floor. In thinking through this my view is how hard will it be driven? I have 33's and am in need of a new lift kit too. I do not do any serious off road driving. Mainly a city driving commuter so I think the a mid-range box will do fine. Thanks for the research notes. I'm going to pull the trigger soon so I can park in other driveways without the embarrassing wet spots. I'll let you know how it goes!
You do know that Jeeps are like dogs right? They mark thier territory to let everyone know that they have been there, claimed the spot, and driven on to tell about it.
Let me know what you come up with! I'll update this as I get more info.
I added this above, but thought I'd put it below to. I just got off the phone with Harvey who owns/operates Red-Head Steering Gear. Just more info to have. There is also a Blue-Head Steering Gear out of North Dakota if anyone is up there. Red-Head is out of Seatle area, but ships all over...both do in fact.
Ok, one other place I have looked:
[*]Blue-Top Steering Gear will rebuild my box for $175 and can rebuild with a quicker ratio if I like for an additional $80. Ryan also uses custom ball bearing sizes. He states a 24 hour turn around, of course you have to ship it to North Dakota, so you won't get it back tomorrow. Again, US Postal flat rate box - If it fits it ships for $15. If you look him up on the web, do it on Google!
All good info. Thank you. I am going to discuss with my jeep shop here in town also. Any feedback I will forward. I may take it to them for the install because my time is very limited right now and I hate pulling her apart and getting sidetracked for 2 weeks.
You could even flip the tie rods as well if you feel so inclined... i did this setup on my CJ7 and my daughters Scrambler and I love it.
The HD tie rods are greaseable and so far so good.
I use a PSC box on one and a AGR on the other... both very good and don't leak.
the stock ones always leaked on all my CJ's with bigger tires... even after you put the new seals in... didn't matter, it leaked.
Final assembly
http://www.certifiablejeep.com/images/freejeep/page72/large/IMG_3711.jpg
and the write up(s)
Down the bottom of this page and onto the next...locker install is in there too.
http://www.certifiablejeep.com/freejeep/freejeep71.php
Middle of this page and down... also brake swap and hub swap from 5 bolt to 6 bolt.
http://www.certifiablejeep.com/TJScrambler/tabscrambler5.php
PS> You can also but a steering box bracket upgrade and a brace if you feel so inclined. I can spend your money just as easily as I can spend mine, so I have plenty of ideas.
The AGR IS $419.99 at Morris 4x4. Maybe a little more than direct but they answer the phone and if you need a return they will take care of it
Did the AGR bolt right up? Did you have to midify and/or create new hoses?
I have the bottom of the line Omix kit that I bought a couple months ago for about $100, and so far I'm happy with it on a daily driver. Greasable ends and comparable in quality to OEM. Also installed a Borgeson steering shaft ($250) to reduce wheel play a little.
I think what I am hearing here and elsewhere is that if you wheel a lot in rough places, like bouldering or lots of walls then a stronger box may be warranted and $400-$600 for just a box is justified.. But for a daily driver on 33's or even 35's then a reman or junkyard box would probably work. There are Durango and J20 boxes if you don't mind some piecing together that can offer a variable rate; and there are reman shops like RedHead, Lee, BlueTop that would build your box or personally stand behind their box and there is the local parts counter that stock remans. Seems I am only limited by my bank account.
I think at this point I am going to go with the RedHead Steering box with a 15:1 mod ($220), AC Delco pump for a GM truck ($49), Rugged Ridge HD Tie Rods and Drag link ($189) and a beefed up mount ($100) and pay about the same as a PSC steering box. Thoughts?
On my write up I'll include all my research and links with pictures and all that. Can't wait to get to drive her again. Ugh. I hate waiting.
I have only run 33's on my rigs... pretty much all of them, a couple 31's and the stock steering boxes always eventually leak.
I finally made the decision after the 6th or 7th replacement, or seal swap out that I would do it once and never do it again... it is way too much work.
Either pay more now in money when you have it all apart, or pay more later in time when you are leaking and will have to do it all over again.
Just my $.02, because I hate re-doing things over and over... only took 6 times to get it through my thick cranium
