Restoration Hardware (The Nuts and Bolts)?
53D Scrambler
Hampstead
NC
Does anyone have a resource for hardware sizes(length, dia, thread pitch) for standard restoration items such as: Spring mount bolts
Proportioning valve bolts
Bump stop bolts
Etc.
I have all the old hardware but want to replace it with Grade 8 or stainless if I can, I thought if someone had some known sizes available that might help. Otherwise I am headed to the stores with old hardware in hand. Also if anyone has a recommendation for suppliers that would help as well. Lowes/Home Depot weren't stocked very well when I scouted them out this past weekend.
Thanks
Ask around for a hardware/fastener distributor. Only the hardcore guys will know about this place. I found one locally that can come up with just about anything. Don't think I'll even bother looking anywhere else for grade 8 manifold hardware, and they sell single pieces for a heckuva lot cheaper than Ace or HD.
Thanks, I'll check it out. The wife is going to be so pleased about our new weekend plans!
Totally Stainless sells a complete Grade 5 Stainless kit for the scrambler.
They come packaged in individual bags for each use. And you can get a kit taylored to Hard Top, Soft Top, Half Top.
Or you could order a nice assortment of Grade 8 stuff from one of the vendors off of eBay, and then just have extra stuff around. I did that and got a complete kit of 1/4 - 5/8" 1/2 - 6" long. Got like 6 different boxes from Plano to keep the assortment divided up in. Kind of like fishing boxes with clear lids. Now whenever I need something I just go to the bolt boxes and throw out the old. Cheep insurance.
I also have a set of metric stuff too, but that is more for the TJ.
I have eBay links for both if you are interested. They are good dealers.
Carl
Totally stainless is where I got my bolts from. The kit included the following
BODY KIT - Body Bolt kits include one of each component kit, including:
Antenna Mount(73-86)
Back Cab Panel (CJ8)
Battery Box/Firewall
Body Mount(including big body mount washers!)
Front Bumper
Cowl Vent
Dash
Door Handles
Window Cranks
Door Latches
Strikers
Limiter Strap Bracket
Interior Door Handles (CJ Hardtops)
Fenders(does both)
Fender Flare(1976-86 CJ’s & Wrangler)
Front Seat Mounts
Fuel Filler(1976-86 CJ’s & Wrangler)
Gas Pedal & Steering Column(1976-86 CJ’s & Wrangler),
Hard Top Fastener(CJ7, Scrambler, Wrangler)
Headlight/Turn Signals
Under Hood Brace Rods
Hood Hinges
Hood Hold Down
Hood Latch & Support Rod
Horn
Overflow Tank & Washer Tank(1972-86 CJ’s & Wrangler,includes Jack mount)
Jack Bracket(1976-86 CJs)
Master Cylinder & Hydraulic Clutch Cylinder(1972-1986 CJs)
Mirror(does 2 door mirrors; all but 87-93 full steel doors on Wrangler)
Radiator Mount
Rear Bumper(1976-86 CJs)
Rear Corner Braces(Scramblers)
Rollbar
Side Marker Lights(1976-86 CJs),
Soft Top Frame(Wrangler)
Steering Column Mount
Spare Tire Carrier, Tail Lights(1976-86 CJ’s & Wrangler),
Tailgate Hinge(CJs)
Transmission Cover
Visor(does both Hardtop & Wrangler)
Windshield & Door Hinges(1976-86 CJs & Wrangler)
Windshield Hinges(does both;1955-86 CJs)
Windshield Hold Down Bracket(CJs)
Windshield Washer Jets(Wrangler)
Windshield Latch(does both)!
If you go to their web site they also have other kits for the frame look on page 65 of their catalog.
I have used Totally Stainless for many restorations. You get just about everything you can think of. I think the Scrambler kit has over 700 pieces. I used this kit for my 84 Scrambler and added grade 8 for suspension, motor and frame mounts.
Found mine on eBay.
I also used the Totally Stainless kit, part#6-2493 for the hardtop. It had everthing I could possibly need and more. I also used steel bolt for suspension and drive train.
Regarding the Totally Stainless kits, any recommendation as far what type to get, the hex head, button head, or indented hex head?
Just a heads up on the suspension fasteners, automotive industry really liked using 9/16 bolts on things and most box stores (home depot, Lowes, OSH, ACE, Tractor Supply) have a limited supply. I ended up having to go to Fastenal for them. I later found out ordering from Mcmaster would have saved me a few bucks. This was all for grade 8 bolts and grade 8 nylon nuts. At least if you get it from Fastenal or Mcmaster you get a bunch of spares that you can put in your nut and bolt collection.
I would go with Hex head if you want to spend less, or the Indented ones if you wanted to look a little more stock. There is not much difference in cost, but there is a little. I personally like the indented better. I would stay away from the button Heads. I like the ability to put a wrench on the outside, or use something that will give me more grip. Those round heads can be in issue if something happens later.
Do not forget to use proper lube so that they will not gall and come off later.
Carl
Thanks Carl, the hex or indented seem to be more practical, and won't be as problematic as the button head if they need removing again.
I have noticed that, particularly the 9/16 x 4.5" for the leaf spring bushings into the frame mounts. Found some 5"ers, I think I will re-condition the stock one if I can't find replacements.
