jhopcj8
- Highlands Ranch
- CO
I have been on a continuing quest to try to figure out my lighting/turn signal problems. First, my headlights would simply not come on at all. That ended up being a problem with the floor dimmer switch, it was replaced and now the lights turn on. Then I had to replace the passenger side parking light, as the assembly had fallen apart. Once all that was done I discovered that the front parking lights would not flash with the turn signal, at all. I then replaced the turn signal switch and now they will flash when the lights are off, but not when the lights are on. I have no idea what to try next. Any suggestions?
