For the record, it appears that no one is offering an actual replacement for the CJ A/C condenser - a universal seems to be the only solution, for which brackets must be fabricated.
Is the one pictured yours? If so, and it's leaky, you could likely take it to your local radiator shop have have it fixed.
If you find a source for a new one post it up, but I believe you are right that you will probably have to get a universal unit and fab up mounting brackets, and use adapters to convert from your flange fittings to orings.
