TF999 Automatic Transmission???
driveby
Jasper
AL
All I've ever fooled with are the manual transmissions and not the factory autos. I have run across some '86 running gear I can pic up at a decent price. I'm interested in it for the Dana44 but was wondering if the TF999 automatic transmission was worth fooling with. Are they strong enough to hold up to not too harsh off roading?
Supposed to be good trannys, with the big negative being no overdrive.
I have two in my shop, planning on swapping one into my green/street Jeep.
I've had one in the scrambler for 4 year with occasional, but dufficult, offroading and no issues with the tf999. I rebuilt it myself with no problems. As mentioned there is no overdrive and most have no lockup torque converter. Without the lockup converter the engine will run about 200-300 RPM's higher due to slipage so when calculating gear ratio's be aware.
I have 35's with 4.11 and run about 2850 RPM's at 60 MPH (a little high)
It is actually a pretty tough little transmission. Very easy to rebuild and lots of parts out there to toughen it up even more.
The CJ version as said has no lock up and no OD gear. But they are pretty much the basis for the Electronic version the AW4 that does have OD and can mate to the Dana 300 with a spacer ring.
If you can live with no OD it is a pretty good off road transmission that is short and durable, light too.
Carl
Thanks guys. The transmission I have ran mostly over the years is the T176 and there's no OD there so I don't think that will bother me much. I'm thinking if I get it I will put it in the 83 Scrambler I'm picking up Saturday and taking the T176 from the Scrambler and putting it in a CJ5 I have sitting there with no motor or tranny. I would try the TF999 in the 5 but I'm afraid there won't be enough room with the longer tranny and shorter wheel base.
Dang, you sound like me. I want the TF999 in my green Jeep, and want to put the T176 currently in the green Jeep, into the tan Jeep. Tan Jeep currently has a T5
I have a 999 in the 8 Scram--anyone know where to find a how-to on installing the AW4? I would like the overdrive....
