3rd brake light wiring
FlagJeep
Flagstaff
az
Maybe it is already somewhere in a thread, or maybe it should be obvious to me, but I can't seem to figure out the right way to wire the third brake light (LED in the spare tire) on the scrambler.
From what I can figure out the brake and the turn light are controlled through the same wire and are the same intensity. This would leave me to believe if I hook up to one side or the other occasionally my brake light would blink when turning a certain direction.
Maybe I am way off here, so I figured I would ask before cutting more wires.
Thanks
Thanks
Here is one option:
http://www.amazon.com/Pacer-Performance-20-702-Black-Circuit/dp/B001S16Z7W
It states it is for LED's (this is important as most LED's don't have enough resistance to ground for the logic boxes to work properly)
For the price it seems to be cheaper and less hassle than fabbing your own.
HTH
Run your self a single wire from the brake light switch under the dash back to the third brake light you are gona use and ground it to where ever you can... Therby bypassing the blinker flasher,,,, wala
White wire (I think):
