Rear seat - rear facing
schmied
menifee
ca
I've gone ahead and bought the Bestop rear seat with the extended head rests; however, I've yet to install it. I've been looking at installation options. I'm going to have my 7 & 5 year olds back there and obviously safety is the biggest concern. I was looking at the buying the rockhard extended rollbar and mounting the rear seat in the normal position. The issue that I've got with that is that I'm stuck with using lap belts if I mount in this position, so I was thinking on mounting the seat facing the rear, up against the bulkhead underneath the factory bar. Then I could use the factory bar to mount 3-point belts. Has anyone tried this? Any advice would be greatly appreciated.
Thank you in advance,
I have that seat. I wanted the forward-facing configuration, but faced the same seatbelt dilemma. I added a hoop behind the rear seat to mount the shoulder harness. The hoop goes ties into the cage - the tube that runs along the side/above the rear wheel wells.
Looks awesome Manhattan. Is your bar mounted directly into the frame or on the tub? I had thought of that as well but was hoping to avoid the issue of having a "permanent" bar running directly through the back of the tub. I'd like to keep it optional to fold the rear seat without having a permanent bar in the way. Guess I just need to make the decision and go with it. I do think that the configuration is the safest way though. Thanks for posting Manhattan!
I know the seat fits facing rear slightly forward of the OEM seat mounts so you have to reinforce the sheet metal in the floor when you bolt the seats down. I'm not sure where it lines up on the roll bar as far as mounting seat belts. I would think that in order to get a bolt through it, you are going to be tight with the rear extension.
i had mine rear facing for years...worked great...then when i put a cage in...i did as manhattan..and put a support loop in the cage..i faced it to the rear because i ran a half top and did not want to have to remove the bulkhead to seat 4
Yeah, the rear seat shoulder bar connects to the cage (connects the B and C pillars over the rear wheel wells) which is tied to the frame and rock rails.
These may help a bit more...
This picture just convinced be to not line my bed next week after it gets out of the paint shop! Amazing :headbang:
IMPRESSIVE MANHATTAN!!!
Maybe someday I'll have the cash to do that to mine :) Nice job!
Thanks for posting!
I'm either going with the rear facing underneath the stock bark, (for reasons you stated, I don't want to remove my bulkhead as the previous owner had it Rhino-Lined in place) or I'm going to go with the Rock Hard bar extension and put it in front facing. Only problem with that is I need to shore-up the 3pt belt issue if I install it front facing.
