What is the best CB setup to go with?
FlagJeep
Flagstaff
az
Since I am starting with nothing, what is the best overall setup for a CB radio? I assume a big antenna and a unit with a base, but not sure what the SSB or AM CB radio? Something newer like a Cobra 29 LX or Uniden 880 or Uniden 980?
There may be a previous thread on this but I dug for awhile and could not sort it out of all the other radio threads.
Thanks
Here's the kit I am looking to go with, it comes with everything including the calibration meter as well as the antenna and Jeep CJ specific mounting plate (the antenna mount fits CJ's even though it says 87-06). The CB itself seems to have some pretty good reviews.
I like it because it is small and out of the way. There are several other complete kits available as well if this one does not fit your application. :drool:
http://www.rightchannelradios.com/cobra-75-jeep-off-road-kit.html
I use this with a spring base and a 4' Firestick
Just need to make sure it grounds, I had to add a ground wire to one bolt that attaches the tire stop to the body.
never a fan of those. A buddy of mine runs one, he loves it, but I hate it. I prefer one with a separate mic because the mic for my CB gets tossed around in the Jeep alot. Its A LOT cheaper to replace a mic than it is to replace one of those units.
Just ordered a Uniden 510 after reading reviews for a fair while. I never have liked those "all-in-one" mics either. On a boat, which is similar to a jeep, you change VHF channels, turn it off, change the volume etc. while laying it down or picking it up, or just gripping it hard because of a tense situation. I know they're supposed to "lock", but they seem to "unlock" too. And then it's difficult to "switch and answer on channel __." Not to mention you leave the mic in a handy place or keep it in your hand as you steer and sooner or later it gets itself into trouble... Just my:twocents: Or as my grandmother used to say, "another county heard from."
CB selection is one of those things where everyone has different opinions based on their experience and values... so FWIW here are some of mine;
Most major brands will have options for similar quality and features at competitive prices, so I won't suggest any particular brand/model without more information about your specific needs and budget. I find SSB and built in SWR meter are not worth the expense, and tend to make the unit more bulky than I like (you really only need a SWR meter once when you install a new system or antenna (most CB shops or truck stops have a SWR meter you can use free to setup with). If you intend to tweak the power output (not exactly legal but commonly done), then you don't want a super compact model.
If you're into a more serious setup, a CB with 10-meter unit adds a lot of capability to a radio but also requires a license to operate.
What will be different in otherwise similar performing radios is the design/layout/controls. You want to pick a unit that will fit and work well in the place you intend to use it;
If you're mounting inside a console (like a Tuffy box), a front facing speaker and mic connection is important
If you're going to mount it up high then a bottom facing speaker is probably better.
If you run with top off, a weather resistant marine rated unit may be desirable.
For an antenna, on a Jeep I tend to like a 1/3 or 1/2 wave length (4" or 6') with internal windings and a lot of flexibility. That's tall enough to clear signal interference from the body and flexible to avoid damaged on the trail... I've busted more than a few FireStick antennae over the years (they work great but don't bend worth a damn). If you're only going to use the CB to talk with the people in your group a hundred yards up the trail, then the antenna performance doesn't really make a difference.
Well said!
I would add if everything else is comparable I would get one with weather radio as an added channel. they usually only add $10 bucks or so, but it can be nice to check forecasts and get weather alerts up in the mountains or in case of hurricanes.
Carl
Thanks for all the feedback. I looked through a lot a stuff as a result of your comments, asked my wife to order me something appropriate, and she came back with a CB that has bluetooth capability so I can talk on my cell phone handsfree, which is nice since I don't have any other radio in the Scrambler. I had not heard of a CB like this, but I have one on the way now. A lot of good reviews on it, the microphone has a noise canceling feature which is supposed to deal very well with road noise, so now when my wife calls me and I am in traffic with one hand on the wheel and one on the transmission shifter I can still talk with her without pinching my phone in between my head and shoulder.
http://www.amazon.com/gp/product/B002IY97O6/ref=oh_details_o01_s00_i01?ie=UTF8&psc=1
Thanks again
I don't need the cigarette option, but the one on the left is a good look
Where does one get that? I have the OEM AM/FM/CB. Figured I would mount a separate antenna rather than use the splitter, since the OEM radio + CB antennas are apparently rarer than nutmeg hens' teeth.
The cb antenna mount is sold at quadratec. The cb am fm antenna I only seen twice. And one was sold on here last year I believe. Its on my search list also...
Sent from my SPH-L900
