Your prefered CJ8 tire size poll
Based off the most common five tire choices which do you prefer for your CJ8?
  • Total voters
    319
I know I'm new around here, but my $0.02 is the 35 x 13.5 - 15
I love the way they look, sound, and ride, but then again, I love the fact that I finally own a CJ8
That looks Awesome. 10 or 12 inch wide rims? :wave:
one in the pic is on 35's, 4in spring under, 3 in body lift, only trimed the very corners of the rear wheel well. The rear flares are Bushwacker YJ Pocket cut outs. They mounted over the raised edge of the Scramblers rear wheel well.
You are a rice farmer???
I grew up rice farming. I work as an engineer and musician now, but I still own shares in the farm. When i head back, 33" tires make a big difference in the mud. Around here, there's very little rock crawling or sand running and there's definately no snow driving. But we do have mud! Since my last post, I've replace my tires with 33" and I like it. I've got a 3 inches of lift and I think it's just right. Anything bigger, and I'd probably have to upgrade to a V8.
31s fit nicely. 32s might work but I think 33s are going to rub. Just based on my 31s when I was stock height.
Dain
Ha! my 31's rub, but I think it is because I have narrow tracks and steel rims. I am told that if I switch to wagon wheels, they won't rub. Not sure how the wheel makes a difference but I'm willing to try anything. An axle swap would be fine to but I'm worried about how hard it would be to find the wide tracks in 3.73 (I would try 4.10 if there was someone who could help me understand how much of a change it would cause?) but then I also don't know what kind of money I'm looking at for an axle swap.
The wheels would make a difference based on the width and the backspacing. You can try spacers if you don't want to swap the axels yet.
Dain
If you go with spacers, go with Spidertrax. I have put 10s of thousands of miles on multiple sets on multiple Jeeps with never a problem. The last set I had was on a NT '76 CJ7. I also currently have a set on my Commander.
I voted 33s but I plan to eventually switch to 35s when I rebuild the Jeep again. I have 33x13.50 LTBs on DC1 15x10 rims. I have a 4 inch Superlift kit with Currie shackles, it doesn't rub. That's with a V8 and a winch weighing the front down
I can add my $.02 now, last weekend I purchased 6 rims and 5 tires for the princely sum of $240. Not stock wagon wheels but some decent 15x8's with the correct 5x5.5. 3 of the tires are Mud Kings in great shape. Tires are 31 10.50's. I had one tire mounted and tried front and rear. For street driving the 31 fit good, even with the front end drooping from the old winch. But, getting it on the Scrambler and looking it over my wife and I both agree at least a 2.5" lift and 33's. My current wagon wheels are 15x7 and the 31's looked better on the 15x8 rims. Thinking these 15x8's are getting re-painted black as well.
I will append my above post to 31's. After the lift and fitting the 31 they look good. However, going for new BFG mud terrains and will use the 1 mud king as the spare. Pics will be posted this weekend.
I agree. I have 2.5 of lift and 31s. The same tires I had before the lift. They look good. I may go up a bit when I have to replace them, but I have a few miles to go before making the call.
Dain
I prefer 33 however I currently have 31x13.5 on 10 inch wheels. Nobody seemed to complain about 4 inches of tire outside of the fender flare but after moving to Pennsylvania I believe that I will need to choose a different option.
Welcome to our site. I'm running 31x13.50s on my CJ-5 with no flares and 12 inch wide wheels and haven't been stopped here in Indiana or in Michigan. :need pic: :woohoo:
:wave:
I got new shoes for my Scrambler last weekend. I had 31X10.50's on it that the previous owner had put on 15 years ago. I just got 32x11.50's put on it. Now, I realize that tread is deep on these tires, but WOW, this is some difference.
With 32's
With 31's
