Bumper End Caps
I worked in the injection molding industry for 10 years as a mold and die tech, And yes these are some small parts but the mold is going to be very expensive if you water cool it and install air poppets and all that stuff that's required to run hot material.
Having worked in the field I would not be venturing down this road unless there was profit to be made because of the intial cost involved in making a mold.
I would think you would be better off having them made from aluminum and cut with a high speed cnc machine. Then your only cost is going to be getting a plastic end cap measured up to input into a cnc machine then sand blasting. As small as it is it would take no more than 15 mins to cut one.
Just for example we had 5 gal bucket molds that cost 50k and up ucan mold in the threaded studs but that's gona drive up the cost, If you choose not to mold in studs or inserts the you have to have threads cut in bosses to create a place to thread the studs and that's gona drive up cost.
yup, when I refer to rapid prototyping I mean 3-D printing. Printing each end cap with my printer is about $78 in material alone. ABS is not the best material to use for this so there might be some better alternatives out there that are both stronger and cheaper. The rough quote I received for doing a left and right hand mold with the threaded inserts was around $20k. Once the molds are done small runs would only cost about $10 a pair.
What are the patent laws on this, if any? (not to rain on your parade, Alex)
Whats the thickness of these parts? A 5 gal bucket is roughly .095 to .125 through out. And with hdpe you can fill a 5 gal bucket and drop it from 8 feet and the bottom wont split. You can get regrind hdpe CHEAP and throw in some uv additive and bam cheap and tough
You can stamp any piece of sheet metal you want. But a jeep stamped tailgate has to be an officially licensed reproduction. That's what I was getting at
Based on the current patent laws, wouldn't any patent on these have already expired?
Whereas Jeep trademarked items are protected.
Patent laws??????
Karl
If this is in response to my post..
I was merely expanding on JJ's responses.
Not saying that there ever was a utility and/or design patent on the bumper caps, but if there were they would have expired by now.
That was what I was wondering ^^ When I was looking into reproducing some of the soft top plastic pieces, a 3D printing company said they wouldn't touch it because of patent protection. I didn't even get to tell them how old the designs were, but that was the question I posed here. Since I have no background in patent law, I'm glad someone may :)
35 U.S.C. 173
Term of design patent.
Patents for designs shall be granted for the term of fourteen years from
the date of grant
And just to be inconsistent..
35 U.S.C. 154 Contents and term of patent; provisional rights.
(a) IN GENERAL.—
1) CONTENTS.—Every patent shall contain a short title
of the invention and a grant to the patentee, his heirs or assigns, of the
right to exclude others from making, using, offering for sale, or selling the invention throughout
the United States or importing the invention into the United States, and, if the invention
is a process, of the right to exclude others from using, offering for sale or selling throughout
the United States, or importing into the United States, products made by that process,
referring to the specification for the particulars thereof.
(2)
TERM.—Subject to the payment of fees under this title,
such grant shall be for a term beginning on the date on which the patent
issues and ending 20 years from the date on which the application for
the patent was filed in the United States or, if the application contains
a specific reference to an earlier filed application or applications under
section 120,121, or365(c), from the date on which the earliest such
application was filed.
I could understand being worried about a part that Jeep has given a license to a company to produce and someone goes and makes the same item. But, if its not made by anybody make it and who cares. If i had the ability to make stuff like that i would have all kinds of parts made. I have an Opel GT. We go through this all the time. People make the part and then sell it to opel owners to get their money back. No problems.
Karl
(a) IN GENERAL.—
(2)
Since we have totally hijacked this thread; ^^^is the current term of a patent after the change in 1995.
The rules for calculating patents terms changed when the US implemented policies set forth by the Agreement on Trade Related Aspects of Intellectual Property Rights (TRIPS). Prior to this implementation, the term of a US extended 17 years from the issue date. However, to be consistent with the TRIPS recommendations, the policy in the US changed in 1995. The current patent term extends 20 years from the earliest filing date instead of 17 years from the issue date.
Either way times up.
Now back to the original post topic:
https://www.cj-8.com/forum/showthread.php?38082-MDJuan-Tubs&p=318093&highlight=#post318093
Post 335 by opelgtboy
Patent Laws? Really?
Can't someone just 3d scan it and put them onto a 3d printer, make a mold and sell them?
I thought these where just for people on this tread, not for mass distribution on Quadratec.
With that being said i guess its better to be safe than sorry?
Im still in to buy the end caps regardless of the patent.
I'm not to concerned about patents, for one the age of the part and second a patent is only good if the original user wants to enforce it. Seeing how small the volume runs are (relatively speaking) I don't think there is enough money to be made in these parts to counter the lawyer fees when it comes to enforcing any patent that's assuming there is actually a patent for this part.
Its good that you brought it up. We all got some good information out if it and it is definitely something to be aware of when we try and reproduce parts like we are talking about doing.
