- Landing
- NJ
Christ, sorry to have brought it up.
I'm glad you brought it up too. I just find it nearly impossible to believe that jeep patented the rear bumper design
What about milling them out of aluminum, sand blasting them to get a surface texture, then anodizing them black![]()
I can tell you I work in the machining sector. The majority of your cost will be in the machining of the injection dies. I am just guessing a little but selling hundreds of these may be the only way to get the cost down to a reasonable amount of money.
I worked in the injection molding industry for 10 years as a mold and die tech, And yes these are some small parts but the mold is going to be very expensive if you water cool it and install air poppets and all that stuff that's required to run hot material.
Having worked in the field I would not be venturing down this road unless there was profit to be made because of the intial cost involved in making a mold.
I would think you would be better off having them made from aluminum and cut with a high speed cnc machine. Then your only cost is going to be getting a plastic end cap measured up to input into a cnc machine then sand blasting. As small as it is it would take no more than 15 mins to cut one.
Just for example we had 5 gal bucket molds that cost 50k and up ucan mold in the threaded studs but that's gona drive up the cost, If you choose not to mold in studs or inserts the you have to have threads cut in bosses to create a place to thread the studs and that's gona drive up cost.
