Here is a little write on my painting process. This will focus on the doors. After the door were sanded to bare metal with 80 grit paper on DA sander, I applied 2 coats of white SPI Epoxy primer to seal the metal. That was applied with my Devilbiss Starting Line HVLP that I use for primer. It was sprayed with a 1.8 tip.
Next, two coats of SPI 2K primer was sprayed on the doors. Wait 10 mins in between each coat. This was sprayed with the same primer gun and tip. The fan adjustment set wide, about a hand length spread at a hand length distance from the panel. The pressure was set at about 25 PSI.
The 2K prime is a building primer that fill imperfections and is easily sandable. I then sanded with 400 grit paper on a long block dry to flatten the panels. The end result is this.
You can see some spots where I went down to bare metal. This is OK. If it were a show vehicle or street rod, I would have stopped before bare metal and reapplied 2 coats of 2K filler primer and sand flat again. On this Jeep, I want as little paint as possible and I want to emulate the factory results, so I stop here and carry on with my sealer coat.
The sealer coat is Epoxy reduced 25% with regular Urethane reducer. It's important to let the Epoxy sit and induce for 30 minutes before spraying. The panel gets 2 light coats of sealer 30 mins apart to seal the bare metal, provide adhesion for the base coat, and to give the base a uniform color to build on.
The sealer was applied with the same gun, this time with a 1.3 tip to deal with the thinner material, and with a faster spray technique to prevent runs. It lays very flat when sprayed in this manner. It's OK not to get full coverage here.
Next, I applied 2 coats of PPG Omni Jamaican Beige Base coat. This mixes 1:1 and is ready to spray right away. This is sprayed out of a similar Devilbiss Starting Line HVLP with a 1.3 tip and the pressure around 25-28 PSI at the gun regulator. I typically set my compressor at 100PSI and choke it down at the gun.
After 2 coats, 30 mins apart, and 30 mins after the last coat, it's time for clear. My clear gun is a SATA NR2000. This gun has a 1.4 tip and is set at 28-30 PSI. I typically use it with the fluid needle set pretty wide open and the fan as wide as my primer setup. The SPI Universal clear mixes 1:1 and is ready to spray immediately. I applied 3 coats, 30 mins apart. On the first coat, it's OK not to make it perfect. I struggle with this often, worrying about trying to make it slick on the first pass. DON'T do it. It just leads to runs. Spray the first coat medium, the second coat wet, and the third coat wet. It's important to work quickly here, so one area doesn't set up and dry before you are done with the whole panel, or you will be in danger of getting overspray on the section you finished first. I'm learning as I'm going so I figured I would post my observations to help others who are interested in painting their project themselves as well.
