Need Help - Brake Fluid Loss
Bryanf
Clarkesville
GA
I haven't driven the Tan scrambler very much since before Christmas due to the cold, rain and snow. However, every time I have driven it I've had to add some brake fluid. Never had a problem before. The fluid is running down the inside of the firewall behind the pedals and into the floor pan. Is there a gasket or o-ring between the master cylinder and the firewall that can be replaced or should I go ahead and replace the master cylinder? I'm not exactly sure how the brake assembly goes together from the brake pedal to the master cylinder.
Thanks for any feedback you guys can offer.
Yeah, that's pretty much what I figured. Is it an easy replacement?
like Sunshine said bench bleed the master, the problem usually is the wheel cylinder bleeder valves break off because they rust up. Soak them good in liq wrench or your fav stuff and then soak them again. Be light with the wrench when loosening them and you may be ok... good luck!
Ok, so the master cylinder replacement was fairly easy but I found a surprise when I drained the fluid out of the old one. An original ignition/door KEY. I guess some previous owner had put it in the master cylinder reservoir to hide for a spare. I would never have thought to look there for a spare key.
Interesting. What condition was it in?
Agree with the others. Replace the master, they are not terribly expensive. Now that it's weeping, it well could suddenly get worse. Not worth the risk. Swapping is pretty easy. Bleeders are dirt cheap, order replacements just in case, so if you have to take one off with vice grips, so be it.
Bonus: Not needed, but the difference between easy and really easy. Get a motive power bleeder. Makes the job so much easier and quicker. Might not be worth it for just one brake project, but if you have more than one car project, you will love to have it.
