Refinishing side board from walkerhiound
zr10054
Car and Gun Junkie
Gonzales
La
I bought a set of side boards that were built new by Walkerhound about 5 years ago. He really did a great job on these and all they need today is a little sanding and refinishing. They are sanded and I should refinish them this week. Then I will post pictures.
*thumbsup*
I found in the heat and dry climate of Colorado, I was refinishing them every other year or so.
While I had them sanded, I tried something I saw on American Restoration - I took a propane torch and added some character to them, it helps bring out the grain, then I coated with polyurethane. Your mileage may vary and I recommend this only if you understand the risks!
I recommend separating the boards from the Scrambler before one performs the propane torch trick!
I tried something different. I sealed them then sprayed 3 coats of clear coat. So far I like the results. If it doesn't work I guess I'm in for a lot more sanding.
Oooh, those look really nice! And speaking of nice, your barn/garage has me insanely jealous. I was just on business in Baton Rouge last week and rode by your town.
Let me know next time you are here. I'm only 1 mile off interstate 10.
Very nice. what did you use to refinish them? I'm planning on refinishing mine in the near future.
I sanded these down to the wood. I then sprayed one coat of automotive clear coat and let it set overnight as sealer. I came back with four more coats of clear coat. I'm not sure if this was the right way to do this but it came out good. I guess I'll just have to see how long it last.
I went the clear coat route as well on them... but mine were FAR more weathered than yours were.
I put a coat on last night and one this morning... on the backside... so we will see how they turn out.
I will do the top side tonight after I clean out the grooves and finish sanding... they are a bit rough.
I think they just have more character.
I used a DA sander on mine. I think I would have sanded both sides before clear coating though.
I sanded both sides, it was the grooves that I didn't have a nice size rotary sand paper bit for... picked one up and zipped through it quick.
I wanted to keep the original stain in there, but get the fiberous and other junk stuff from there.
Pics shortly.
I now have to rebuild the mounts... they were pretty far gone, but all in all, saved another piece to use on the Scrambler or perhaps sell... we will see.
Your clear coat was a good idea, I like how they turned out.
They look good to me. I put four coats of clear on mine and They look like glass.
