High revving engine
Escondido
BOERNE
Tx
I have a howell tbi on a 258. This has happened 4 or 5 times. The engine will start revving high even out of gear. Oil pressure gets high and will eventually push some oil out onto the manifold. Almost looks like it is coming out below the TBI. Only happens after I have been driving for a while. Turning off and on doesn't solve it, but if it sits it will clear-up. One time shifting into reverse downshifted the engine to normal idle.
Where do I start looking for a solution?
That happens to me from time to time as well. I turn off the engine, set for a second, push the accelerator to the floor and hold it and then turn the key. That essentially resets the brain in the Howell TBI and clears whatever error may have just occurred.
I do not get the oil issue but I do see high revs from time to time at idle. This trick cures that problem.
