My De-Rustification Project
7/16 thread bolts for the spring hangers.
Thanks. Picked them up today. It was harder than I figured to find grade 8 7/16-14 bolts. Found them at Lowe's. HD and TSC did not carry them.
Yeah Lowes is only one. And they are normally out of nuts. I bought a box a while ago wise investment
I wanted to do some actual wrenching. So I installed the new shackle hangers tonight.
I ordered the brake line kit today. Should be here in a couple of weeks. I have the extension line for the rear already. Not sure if I will need extensions up front but I will see once I start putting these on.
While I a waiting on the brake lines to arrive (the clips came yesterday), I will be attaching the fuel tank. I am also thinking about the fuel lines. I got a list from Dustin this summer, so I will be looking at that to order what I need: Tank to Carb, Carb to Tank, Tank to canister, 5/16 rubber line. Any good sources? Direct from Inline Tube?
You using the rubber backed clips?
My 2 '7s don't have rubber in the clips, and I haven't gone to look at the Scrambler to see if they had rubber from the factory.
I ordered these to use on my rear axles, but wondered if there were any drawbacks to the rubber (maybe holding moisture/rusting the lines?)
http://smile.amazon.com/gp/product/B003BZQ7EE?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s00
As far as I know, no. Mine do not have the rubber. I have not opened the package yet but the pic when ordering them did not show it.
And the existing ones on the rotting frame don't have it either. Interesting question though. Which is better? Hmmm
So I am assembling and mounting the gas tank. I got a strap with the tank that was too long so I cut and and rebent it as well as drilled a new hole for the bolt.
Strap attached
And my brake lines arrived. Woot.
Mounted the tank. Will flip the frame in a bit. I had to touch up a spot on the frame with paint. This job deserves a beer while I go in and watch VT lose to Pitt.
And I pulled the brake lines out of the box. Should be fun.
I've been looking at my new brake lines all morning and I'm just trying to build up some motivation to start installing them. :)
Need to be finished by 6:00 so I can watch LSU and Lenard Forenete kick butt.
I actually got all mine installed today.
Cool. Got pics, i don't want to go out in the rain and crawl under the Scrambler to see where the clips go and make sure I know the orientation of the lines.
Ok. I manned up and crawled under and then ran the lines I could. No axles yet so that will wait. If I get the proportioning valve off of the old frame I could run more. And connect them.
Dain, I forgot to buy the clips. I can't understand why they don't just include the clips in the kit. All the holes are still in the frame so placing the clips back in their original location should be easy. I also had to reshape almost every line.
I was also going to do the brake job today but I forgot to order the new one piece rear axles.
