My De-Rustification Project
Dain, I forgot to buy the clips. I can't understand why they don't just include the clips in the kit. All the holes are still in the frame so placing the clips back in their original location should be easy. I also had to reshape almost every line.
My lines were shaped pretty well. As far as I can tell right now. And the clips that I bought with the kit are too small and the screws are too small. I used the old ones for now.
So i bought some used leaf springs that should give a 4 inch lift. I will see them tomorrow when I pick them up. I will also be picking up the axles from Jim so that I can put them on the frame and move them around. So tonight I ordered bushings and spring plates as well as fuel lines.
Earlier, between work and Payton's baseball, I tried to get the proportioning valve off of my old frame. It is difficult to reach the nuts for some of the brake lines and stripped others. I broke a brake line trying. I ran out of time. I will try to cut the rest of the brake lines another day. I would like to re-use my original valve.
I hope to have pics of the parts soon.
If you can reuse the valve it would be to your advantage. The valves they make now have a bad habit of leaking (Damn chinese parts) I've had two leak in the cj7 (third is sitting on the shelf till I get the time). Mechanic says they use cheap "O" rings so they leak at the rear adapter or front button.
I have heard bad things so when I have more time, I will get back to it.
Picked up some leaf springs for a great deal. Will clean them up and see what I can make of them. And I got some axles to mess with and see how they work on my rolling chassis project. Slow and steady, right?
My mechanic says no. Everything comes from over seas. That's one of the reasons guys are using the adjustable ones.
That's just like us dumb Americans. We've been buying 2nd rate parts for so long we have come to accept it. Worse is that we now expect it and do nothing about it.
When a part is CNC-able like a proporting valve I see no reason why anyone with a CNC mill couldn't be THE GUY that gets in there and makes a good quality unit from decent blanks and fits quality, Dot4 compatible orings etc. that guy would then sign up as a vendor on all the forums and become the goto guy for every jeep bloke looking for a top notch US made brake proportioning valve.
Tell that to MD Juan...
Sent from my SM-N910P
Vanco brakes kinda did that a few years ago, then a bunch of cheaper versions of his brake setups hit the market and people started buying the cheaper stuff.
Quality stuff usually comes with a bigger price tag, and sadly most people now want cheaper over better. Throw-away society and all.
People are learning though that this China garbage is mostly just that. I have a box of part (we all do) which have turned up which will NEVER get on my jeeps. We then go looking for original bits. The bit that really grates on me is that the end seller charges nearly as much as a good manufacturer would when then the part out of china costs like $3.50 or a buckofive.
Another Dumb American buy...... Most of the antifreeze/coolant in the stores are premixed 50/50. So for 80% of full price you get 50% product. Who's the stupid one, the buyer or the seller? And you can't blame this one on China.
Quality stuff usually comes with a bigger price tag, and sadly most people now want cheaper over better. Throw-away society and all.[/QUOTE] I don't mind paying the extra. Problem is company's have picked up on this and raised their price on the same junk.
You are correct about you get half as much, but technically you are supposed to use distilled water when you mix it.
Now, that said, it costs more for distilled, unless you boil it off yourself and collect it, which would cost a lot more.
So, that all said, they say it has distilled water in it.
Half the people use regular water, probably more, so whether or not the minerals in the tap water are doing damage... maybe, maybe not.
Do they use distilled... maybe, maybe not, but yes, this is all along the lines of the pre-packaged world we live in.
Kids won't east snacks now out of a big container, they want the small ones... chips/cookies/yogurt/milk, etc.
It is convienent for car trips, not so much for at home use.
So, it all comes down to how much work you want to do it right yourself using bulk vs. the time it takes I suppose.
Well. My work on the frame started out well. Then I hit a little self inflicted snag.
Started cleaning up the springs by getting the bushings out and then wire brushing off some crud.
Then I took the brake lines off of the donor rear axle and sprayed it with degreaser.
Letting it soak, I grab the dremel and attack the brake lines in the scrambler so I can get the old proportioning valve off to re-use. This is where I screwed to pooch. While cutting the fuel line that was attached to it, the dremel slipped and dug into the port that feeds the rear. It is trash now. This sucks.
By the way, does anyone know what the wires are that are coming off of the top of the valve? They were not connected to anything.
I guess I either search for a used valve or buy a new POS one.
I can check for a proportioning valve on a parts Cj I have here. It's an 83 with power brakes. Is yours power?
Wires that go off the valve are for the brake light in the speedo cluster. One runs to a ground on the ignition switch and the other goes to the brake light. When you get a leak the shaft in the valve moves and completes the circuit (grounding out the light). Your parking brake can also ground out the light if left on. That's a bad break on cutting the valve.
