- Ashburn
- VA
Wires that go off the valve are for the brake light in the speedo cluster. One runs to a ground on the ignition switch and the other goes to the brake light. When you get a leak the shaft in the valve moves and completes the circuit (grounding out the light). Your parking brake can also ground out the light if left on. That's a bad break on cutting the valve.
Thanks. I will look for a harness missing those wires plugged in. And yes it sucks. I have leads on some replacements but will see in the morning if I can fix this one by swapping the cut part out.
