My De-Rustification Project
So I was too busy with family stuff this weekend (and ill today). All I was able to accomplish was to add the t connector and run the soft line to the hard line to the charcoal canister. I need to get some clips to secure the hard lines to the frame some more.
Every step is hopefully in the right direction (no mater how small). Coming along nicely. You'll feel like your accomplishing things when you start with the body. Hang in there.:cheers:
My wife saw it this weekend and asked how much I have left. Ugh. I started to think about it. A lot of little things. And then the drivetrain and body swap (the very big things). Dang it. I need to take a good week off to dedicate to this.
You need 2 weeks... and then 2 more ;)
Looking good.
Was it too much trouble to shorten that gas tank strap
No trouble at all. Measured the length needed, cut it off, then re-bent the fold over and drilled a new hole through the folded section. Worked just fine. Thanks.
As you may know I'm hoping to do the same thing in the next year. It would be worth it for me to spend a couple days with you if another pair of hands would help the process. Just let me know.
Of course. Just hit me up whenever you want and I can let you know my plans. My next phase is to take the winch and bumper off so that I can get the steering box off (gotta disconnect the hoses from the back of the pump too. I hope to get to that this weekend.
So between the few minutes I had before work and the little bit of time after I got home tonight, I took the winch and bumper off to get to the steering box. I got 3 bolts off, one broke off and the last is spinning, so I will hit it with the grinder at some point. Somewhat of a successful (short) time working on the Scrambler.
So far I have added some frame clips for the brake and fuel lines. Then I tackled swapping the steering box over from the old frame to the new one.
Big thanks to Chris (cdvcj8) for coming over and helping. Having two sets of hands really helped.
And connected the steering linkage
To get the box out of the old frame, I had to cut through the steering shaft. It was rusted and held together with cotter pins. I will be getting a new one.
Also put the hard top on and adjusted the half doors for a better fit.
Now I am going to tackle taking the sway bar off of the old frame.
And ...... I just gave up on the sway bar. Who needs it anyway? :rolleyes: :angry: :banghead:
I was able to get the bracket off of one side of the frame, and disconnected from the spring plate on the other side. Oh well. No rush on that anyway, it won't keep me from driving it by not having it on. Been at this since about 7:30 so I think I am done for the day. I will PB Blast some of the nuts for the emergency brake and just wait. Man, there is sooooo much rust on that old frame. More rust than steel. what a POS.
I just wanted to pop in and say your doing great...I've been following your posts....looking good...
But have one thing to say... can you speed it up a bit... lol I want to drop my scram off next for ya to do.... really yours is looking good... my 8 if all goes well will get torn down come spring... or sooner if engine don't hold together over the winter. .. 258 sounds like a little man with a jackhammer inside at the top of each gear.... rist pin.. I believe. .. poor thing don't like higher rpms. .. grrr....
Sent from my SCH-I605
I tried driving my '81 without the sway bar and it drove like crap. You'll want a sway bar for sure.
I had it off for a month when I put the lift on it. I really did not notice a difference but since I use it as a DD, I put it back on. I will figure it out and install one again.
Glad I could help and looking forward to doing some of the big stuff if you need help. Great drive down. Doors off in December!! ImageUploadedByTapatalk1449957756.233485.jpg
