- stafford
- va
I might have some frame brackets !!
I recently bought a rebuilt one from Columns Galore. I think it was almost $400.00 and another $425.00 for core charge. That will make you send the core back.
I imagine it would have to be a usable core.
I have a few stock ones if you need
I agree the column was fine but the primer was trash but I'm repainting the whole Jeep anyway.BTW, zr10054 I did Columns Galore as well and it's worked fine mechanically since. Only small nitpick is the outer casing was probably only an 8 out of 10 and I will probably repaint when I do the frame off.
I just removed a steering shaft from a 1980 CJ7 w/ power steering... if you need it, let me know.
I assume you are using power steering?
The rear would more than likely need a new boot and parts/pieces, but it is pretty simple to rebuild.
