My De-Rustification Project
Never add up the receipts until your finished. My first folder is so full I've started a second one.
So true. But, at this point, I'm the only one counting. And all the rest of the bills are covered, so I'm good!! ;)
I can't believe it is almost 6 pm. I have been out in the garage since 9 and haven't eaten anything yet. Oh well. I did make some progress today. And a step or two backwards (as usual).
Ran the wiring to the back lights and ground them. Busted my bits and had to run out and get new ones. All that is left back there is to wire the fuel sending unit and ground the hitch wiring harness.
It took me forever, but I got the e-brake cable hooked up to the pedal. Then I ran the engine wiring. I need to make one more connection for the power to my electric fans, then hopefully that will be complete. Ran the wiring to the transmission (reverse indicator) and the t case. And I put the hood back on.
So, for the bad........ I tested the lighting. No dash lights. I had tail lights and marker lights. The high beams were on. When I tried to turn them off, the stayed on. I reached down to the plug at the high beam button and then the high beams went off. But no low beams. Looked at the plug and saw that the PO basically taped all of the wires together. No actual plastic plug. Great. Oh and the reverse lights did not come on. I assume it is at the plug on the switch. I will deal with that later. And despite filling the coolant, I have not tried to turn it over yet. No gas and the e-fan is not operational. So tomorrow I will cut the new puck for the radiator and get a longer bolt to mount it to the frame. And I might go to the auto parts place and see about exhaust parts. Won't be able to spend too much time in the garage after today.
Dang, there are a lot of greasy hand prints all over the Scrambler. I will be spending a lot of time cleaning it. Later.
Oh. Any advice on replacing the u-joints on a driveshaft would be great. Do I need to get a press?
Oh and more good news..... The springs that I have on there now are stock (I suspected it despite being told they were 2.5 lift). So once I am done and have it running, I will be swapping the springs from the rusty carcass to the new frame. Just one more thing for the list.
Eating is way over rated when you are working on your Jeep.
Press makes it easier but if you have a large vise and 2 sockets (one that fits the diameter of the cap and the other that is large enough for the cap to slide into). Tighten in vise till you can't tighten then take a 3lb mash hammer and hit the vise while trying to tighten the vise. Heat also helps. I broke my fathers industrial vise removing front axle u-joints on my first jeep. My grandfather and father owned a auto repair garage and used that vise to do u-joints for decades and it took me 20 minutes to break it. This was after they closed the garage. Father ended up making a charcoal fire is the grill and set the piece of the vise I broke in the hot coals for a few hours. He then took the torches are welded it all good. Took me another 15yrs to break the vise again. That's when I learned how much easier it is with a harbor freight press. Just have to be carefull with the press I bent the ears on a driveshaft and had to bend back into shape to get the u-joint to fit properly. Good times (even though my father didn't think so).
I very seldom have trouble changing U-joints but we don't use salt on our roads either.
Nothing like "see me" big sockets to get that job done. :wave: damned autocorrect. I called my wife Adam in a terse text message this morning. She responded equally tersely and followed up with another text saying "and my names not Adam!" Good grief.
Found out why I only have tail lights and not reverse or brakes or turn signals out back.
This happened when pulling the tub. The ground wire for the hitch that was in this harness snagged. Crap.
Oh. And I attempted to turn the motor over as well. I heard a loud click at the starter. Hoping it is just a dead battery. Will try to jump it later.
That kind of stuff is inevitable keep plugging away good luck!
Fixed it. Now to see why reverse lights are not working. Hopefully just the plug on the switch. I have had issues there before.
The first thing I thought when I saw those pictures is man I'm glad I bought the Painless Harness, then I thought about the $899.00 I spent. :)
