Oversteering woes
Not to throw fuel on the fire.... I totally agree with mysunnshine.
When the steering shaft or the steering box was installed, that steering column issue should have been caught at that point with no exceptions.
Except I'll take it a step further,
When the steering shaft or the steering box was being prepped to be replaced, that steering column issue should have been caught at that point with no exceptions.
I'm a firm believer in diagnosing problems rather than throwing parts at a problem till it's resolved.
Also, I realize that most people/businesses don't think that way.
Once the issue is looked at it should be simple to confirm what the problem/solution is. Hopefully your problem will be corrected soon and you can start enjoying your Jeep. :thumbsup:
Yeah, this whole process has been a nightmare. I've taken it to normal mechanic shops and I've had it at 2 Jeep only specialists. All doing the same thing, working from the gear box and back. I've never even had someone mention there could be a potential problem in the column or I would've had that replaced 6 months ago too. It's only because I keep asking questions to you guys that I find this stuff out.
Everyone else says "that's how a jeep is supposed to drive". I've had 4 Jeeps and they've never driven like this!!
Update. So I go and drop off the Scrambler at this shop that specializes in jeeps and has a very good reputation, whom also did the last repairs(steering box, shaft and bushing). I talk to them about what's going on and this is what they come up with:
- Tie rod end bushing worn
- They want to take off my drop pitman arm and go back to a stock arm(I have 4" BDS lift)
- steering box adjustment(aren't these set properly from the factory? And they installed this box)
- probably replace column bearing/bushing.
Thoughts?
What happened to the 1/4 turn of slack that was diagnosed to be in the column specifically?
Sent from my SM-G920V
And i thought u said the tie rods ends where changed?
Sent from my SM-N910P
They were about a year ago, the bushing on passenger side looking a bit worn.
But as to Sunshine pointed out, that doesn't address the column play. And the fact that these guys want to adjust the steering box that they installed pisses me off too.
Sounds like it is time to start turning your own wrenches instead of relying on others. You can't do any worse then these guys.
Just a thought, probably worthless, but my old CJ-5 acted this way when I had bias ply tires on it.
I know in your first post you say you have 33" BFG with no wear, but I just wanted to mention this anyway.
Good luck to you.
Got the Jeep back from the shop. They replaced a Tie rod end they said was worn, put on a stock pitman arm and took off my drop, and adjusted my 6 month old steering box.
Still sucks, no difference. I'm at my wits end. Anyone know a good shop in San Antonio? I've tried to stick to 4x4 or Jeep shops, but at this point I don't even care, I just want the steering fixed.
The steering wheel play HAS to be addressed.
There's no way to make minor steering corrections while driving when you have 1/4 turn of play (especially if your power steering is sensitive). If you want to correct slightly to the right, you quickly turn your wheel clockwise (because you know there's a lot of slack to take up), then everything slams together and you end up with more correction than you wanted, and then you have to do it again to the left! This may not be the whole problem, but it certainly contributes to it.
I have a 1982 non-tilt steering column you can have, if you want to try it out. It will take a couple hours of your time to swap it, but at least you won't be throwing any more money at it. See my thread here: https://www.cj-8.com/forum/showthread.php?46271-Swapping-a-YJ-Steering-Column-in-to-My-CJ8 , and just do the upper steering part.
I don't know what your shop was trying to accomplish by switching back to a stock pitman arm. With a 4" lift, that will affect bump-steer (probably making it worse, unless your drag link is flipped to the top of the knuckle), but I don't see how it could help the issue you've presented here.
Hey JeepWillis, could we see some photos of your Scrambler?
Specifically, a full side shot from each side, and a front shot from down low, encompassing the entire steering assembly, tire-to-tire.
Additionally:
As someone mentioned previously, it's time to stop going to these 4x4 shops, and start getting some real world help.
If turning wrenches isn't your forte', that's perfectly okay.
Everyone who has responded to this thread would be more than willing to come over to your house and help you run this thing down, if we lived nearby... and a town like San Antonio surely has dozens of people just like us who would love to help you out!
Before you go to another shop, look around and join a local Jeep club or off-road club, and find that guru who knows the answer.
I see from you profile that you work in orthopedics. That could mean anything from shoe-inserts to prosthetic limbs, but either way you understand that any series of moving parts must be set up just right in order to work properly... and if everything is set up properly, it must work!
Don't keep chasing shoe-inserts if what you really need is a new hip! ;)
I'd post a video if I could. Just to show the play and the setup. I just took of the steering stabilizer, no noticeable difference.
Super sensitive steering, just a better ride if I don't put my hands on the wheel at all, totally safe!
Additionally:
Everyone who has responded to this thread would be more than willing to come over to your house and help you run this thing down, if we lived nearby... and a town like San Antonio surely has hundreds of people just like us who would love to help you out!
I see from you profile that you work in orthopedics. That could be anything from shoe-inserts to prosthetic limbs, but either way you understand that any series of moving parts must be set up just right in order to work properly... and if everything is set up properly, it must work!
So true Pilot. I've joined a few local jeep clubs and this last shop is a jeep club shop. The thing about all these jeep clubs, I'm the only Steel in them, they're all wannabes with 50k TJs and JKs. They say they know jeeps, but they're just proving they don't understand CJs.
You need to find a generic 4x4 club then. Yes most of the new jeepers are clueless. Talk to the street rod people too. They always know the good repair shops in the area.
JeepWillis, we still want pics. We're four pages in to this thing, and we'd like to see what we're working with! :shrug:
