My De-Rustification Project
Get home and notice one of the headlights is out. Wtf? That one is probably a bulb. It will give me something else to do this weekend. Yay
Oh. And did i mention that I noticed that the heater fan did not come on when I wanted to defrost the windshield. Fun times. But these are just little things.
Swapped out the headlight bulb. Fixed that. Went looking at the taillight harness. Noticed that the ground connection at the frame was broken. Fixed that. 2 of three down. Will look into the blower motor tomorrow.
Put on my half doors. Which of course (for some reason) needed adjusting after moving the tun to the new frame. The pass side now fits better than it ever did. The driver side, well, i stripped a torx bolt on each hinge and was only able to extract the top. But I was able to get the door to shut decently.
As for the blower motor I found the power supply to it disconnected. Hmmm. Ok.
I assumed that the wire coming off of the motor plugged into that. Still no action on the motor after plugging it in.
This is why I run a tap through every hole before I do anything. Also using a gentle impact or screw gun works better than a ratchet because the hammer effect seems to loosen up the bolts a little easier.
Dain I hope you got a multimeter for mothers day. LOL
I have a multimeter. But to test that wire I simply used a test light. It comes on when the switch for the fan speed is turned. So power is making it. I just need to see if the motor still works. It may have crapped out over the winter when the engine was out and the fenders and hood were off and we got a ton of snow. I really don't want to swap that out again. But I am helping someone do it on theirs next weekend. Maybe I do mine at the same time.
Since you are fiberglass do you have a dedicated ground running to the motor?
Heck. I can't remember. ;)
But I was wondering about that when I was looking at it. If that wire I took a pic of is the power, where does a ground wire connect? I only saw/felt that one. And it has been a wile since I swapped out that blower motor.
The stock motor grounds to the firewall. As I've said before I am a disciple of jeepHammer I ran a dedicated one to mine. If your firewall is fiberglass I would expect you would have to as well.
Simple thing is jumper from one of the bolts to a good ground and see if that fixes it.
Great. I will run a test wire to a bolt and see. Thanks
I have a long test wire that whenever I suspect a bad ground I go straight to the neg post on the battery. That leaves no doubt.
I have been dealing with having my stereo cut off after driving a bit. And not consistently either. It appears to be just the ignition power supply as the memory remains for my presets. Tonight after it did it on the way home, I got out a test light and found the ignition power wire. But the radio came on (helped me isolate the wire, but decided that it did not want to cut off, even after waiting 15 minutes. I want to test that wire when the radio cuts off to see if the problem is my wiring or the headunit. Hoping it is the headunit. I want a new one and that may be the excuse I need. ;)
I will try to mess with it this weekend. After this rebuild, I may have run out of heat. ;)
Dain I hate to see you doing all that work. LOL I probably have a yoke laying around here somewhere.
I still need to get the one off of the axle that is on the Scrambler now as well. I just don't want to mess with that one until I have the other one off as well. And no worries, i will give this a little more effort before I throw in the towel and look for one elsewhere. Thanks. I will let you know.
