-6 AN fuel lines and fittings
I was just throwing that out there, because if someone is worried about the quality of the fittings, aviation grade fittings will be of known excellent quality.
One more thing, when using aluminum fittings in particular, be sure to follow proper torque specs. We've been replacing a ton of fittings, lines, and components at work lately because somebody thought that they should just tighten them down until they are "Gutentight". I have a plane right now that a hydraulic shutoff valve is leaking at one of the line connections because somebody "German" torqued it and scored the sealing face of the valve. To the tune of about $12,000.37 Degree Table K Assembly Torque 37 degree tube fittings.png
Made a trip down to Colo Springs this AM and picked up some hose and fittings for pretty cheap. Will see how the stuff holds up.
K-N Filter and PTFE hose.jpgOh and a new fuel filter too.
:thumbsup:
