Muffler Opinions
hefavitzen
BENEFACTOR
Gold Member
Rock Hill
SC
Hey folks, question for you:
As some of you know, I have an 81' CJ8 with a 383, TH350 and 2.73 gearing. I don't wheel it really but drive it to work often. It splits time being a DD with my pickup.
I drive 20 miles a day on the highway to and from work at around 80mph at around 2300 to 2500 RPM (my RPM gauge is small). I think the exhaust is too loud or just too grating on my nerves and I'd like something more pleasant sounding. The exhaust I have is dual, no H pipe, and the mufflers are about the size of a large potato.
Considering I keep my RPM's low and I am assuming many of us here do, be it on the trail or the highway; what mufflers are you guys running that may have a similar setup?
Any input or points to good sources of noise would be appreciated.
Thanks! Jeff
At least get a muffler the size of a loaf of bread.😃
I have 23 year old flowmasters on my mustang and love them. They are loud but the have much quieter ones now with so much drone. I have 40 series flowmaster to put behind the 401 in my 8. They will be loud but I do not care.
Alot of the exhaust companies have sound clips online but they are subjective as to the style of exhaust you will be running and engine vs what the sound clip depicts
Sent from my SM-J320P
Thanks for the feedback Barry! For clarity, do you feel that today's Flowmasters are louder or quieter than your 23 year old mufflers? Just the fact that they have lasted 23 years is pretty spectacular!
I had flowmaster 40 series in mine. It's a 350 with a lt4 cam. 2 1/2" dual exthaust, no H pipe. I drive it trails, dunes, and DD all summer. It sounded great with just the Flowmasters. However after a couple years it got old......or I did. Just this summer I added a glasspack to the very tail of the pipes. MUCH better. quieter than my Toyo's on the highway and still sounds good when I get on it. I can also creep out the drive at 5 am to work or though the campground late night without trouble.
What kind of glass pack? I am shocked that a glasspack is quieter. I personally don't want to listen to it all day long. I'm about to drive it 4 hours to the beach for a week and am kind of dreading the noise. I'm getting old too :(
I kinda miss my side pipes as well...but that is REALLY loud!
These are the ones that I used.
https://www.summitracing.com/parts/jex-a4515b
They helped the most at cruising speed and light throttle. Overall made it much more enjoyable for cruising.
The plan is this winter to build a aluminum fuel cell. When I'm in there and the tank is out I'm going to tuck the glasspacks higher. Right now the rocks may win against them.
You might see if you can contact GADUCKER..... He is a member on here and if my memory is correct owns a muffler shop. I bet he knows some tricks!
My Dynomax turbo mufflers are awesome on my 350. I swapped them in from owning Flowmaster series 40's. I liked the Dynomax so much I installed one on my scrambler with my 258 and it sounds great. They are not too loud at idle and zero drone on the highway. they have a good bark when getting on the gas. The build quality is excellent as well.
I have a 238 with T176 and 2.73 gears. 15 years ago (and ~10K miles ago), I put on a $20 turbo muffler from Autozone. It's been great.
I get performance I want becuase it has just enough back pressure (without a muffler, performance noticibly suffers).
I think todays flowmasters can be more quiet as they have many different "series" to chose from. Mine are 2 chamber mufflers, not sure what series that translates to today.
Well I miss-remembered the size of the mufflers. Looks like they are a lot bigger than a potato...about 16 inches long from inside weld to inside weld.
Here are a pair of photos. Not sure what they are, but they are pretty sturdy.Muffler 1.jpgMuffler 2.jpg
X2
I just did a little checking.... my $20 Autozone Turbo muffler from 10 years ago is a Dynomax Thrush Turbo Muffler that Kane above is giving good reviews.
Autozone now sells that Thrush Turbo muffler for $29.99. Other places like Jegs sells it for $31.87.
I think I have the 2" in/out model (#17702): http://www.jegs.com/i/Dynomax/289/17702/10002/-1
But they also come in different sizes too for the same/similar inexpensive price.
I had a thrush and liked it a lot. I have a flowmaster now and I like it too, but it is a bit too big. It touches the e-brake cable burning through it. But I like the sound.
That's the one. i am very happy with the quality of that muffler especially for the price.
I'm running a Thrush Hush on my '84 CJ7 with an AMC 360, 2.5" into a single 3". Has a nice quiet rumble at idle and sounds great when you open it up but still not overly loud. We use this Jeep on our trails and to get out deer hunting so I wanted something fairly quiet. Definitely quieter than my '79 Cherokee with a 360 and a glass pack.
I've got another thrush muffler (don't remember the exact model) on my '85 CJ7, with the 258 and 4.0 head. Has a great sound, way more noticeable at idle and can be a little loud for extended drives.
I'm noticing as I get older each new build seems to get quieter...
My 85' CJ8 with the current 360 has true dual 2.5" straight pipes. It's almost not even fun to drive over 10 miles because it's so loud. When I drop the 401 in it some form of Thrush mufflers will for sure be added.
I've been very happy with all my thrush mufflers, will be using them again.
Sent via smoke signal
