Iron Duke question
mudbeast2
PORT SAINT LUCIE
FL
Hey guys, I scored a 82 Scrambler in the beginning of the month. Seller stated it was a runner. I could barely keep it running from the transport to my garage. But after a new starter, tune up & new weber carb she runs great. I currently have the front clip off & motor pulled due to a horrible oil leak. My question has to do with vacuum lines. All emission controls were removed my the previous owner. No big deal cause we don't have any testing here in florida. but before i pulled the motor I could not get her to run with the vacuum lines plugged. I had to leave one open. So I had the vacuum advance hooked up to a port on manifold, Charcoal canister had a big vacuum line that I put directly onto the carb. The other big vacuum line on the carb is going to the pcv valve. Egr was not functional due to dry rotted hoses. Besides the fuel tank vent what is the proper hook uo for the canister? Any advise will be great. I will post some pics from my phone. Thank you.
This is the 49 state diagram for an '82.
Also, here is a link with some good info on the system and how it works. It's for the 258, but the functionality should be the same.
It also may help you to determine how to work around some of the missing lines for your aftermarket air cleaner.
I have an extra Weber if that helps! Not going to use it so happy to share with another FL scrambler owner
That's very generous, if the need arises I'll let you know. Where are you located?
