Steering collumn reassembly issues.
Wyatt1234
Orange
TX
On my 1982 scrambler I did some work in the steering collumn, all was well until I tried to put the lock plate back on. It wouldn't go back on the way I took it off, so I rotated it, until it went back on. I've got everything reassembled, and working, but my steering wheel is upside down Now! Any reason why the lock plate would not go on the way it came off? And most importantly, how do I get my steering wheel back on straight. Thanks.
How deep into the column where you? The lock plate has to align with the horn button, so that must also be rotated 180* off somehow.
I'd look at this part and see why it's got the horn button clocked to the wrong position. I believe it should be at about 10:00 as shown in the diagram (and you cant just turn the steering shaft to move it, it has to be installed in that position while the steering components remain oriented in the forward direction).
good luck :fingerscrossed:
Thanks for posting the diagram, it does help. Though even with a lot of tinkering, that collumn is still picky. I'm about to just drill another hole into the back of the steering wheel, so it will line up up with the cancel cam. I drove it today, and everything worked so I think I'll just suck it up, and make good use of my drill press, unless I find a better way.
I fixed it finally, I just flipped part number 10.740 on the diagram over. I guess one of the previous owners tampered with the steering shaft some how. At least I didn't have to drill into my steering wheel.
I have this same issue but cannot see the diagram above. any other way of posting it please?
I can't think of a proper name for it at the moment, but you need to take the steering shaft completely off both ends. the piece I flipped was the joint at the end of the steering shaft that connects to the gear box by taking the snap ring out, and reinstalling it after flipping. If you do this make sure your front wheels are as straight as possible, and the horn contact on the cancel cam, and lock plate cut out for it is in the 10 O clock position. Though you may have to rotate the steering wheel a little to get the shaft back on, but that is fine as long as you don't turn it too far one direction, as our goal is to get it as centered as possible. Im not going to guarantee this will work, as something else might be out of line. Good luck.
Wyatt, was your steering wheel upside-down to begin with?
If not, then that bell joint shouldn't have had anything to do with it... I'm glad it worked for you, though! :thumbsup:
When you had the upper end taken apart, did the shaft itself slip out of place? If part #10.700-1 slipped out of place, it could have been re-inserted 180 degrees out.
CJ7Pilot - thanks!
I think i know what happened, now that I think about it, when I took the steering off for the first time, it was very difficult, as if it were in a bind. I did not remove the drive shaft during this process. When I tried to reassemble the way I dissassembled the lock plate wouldnt go on. So I think a previous owner accidently flipped the steering shaft causing the steering wheel splines to be off, and instead of properly diagnosing the problem he forced the steering wheel on the wrong splines, making it dang near impossible for me to get off, even with a puller tool. Though I believe it is fixed now, so all is well.
