Convert to automatic transmission and steering column
Lookuphere1
Oklahoma City
Ok
I'm looking to convert my 5 speed manual transmission in my 83 scrambler renegade to an automatic with the proper steering column, etc. ... Hopefully a transmission that is good on the highway like my 5 speed.
Where to I find all the parts?
Thank you.
I think if you want overdrive like the 5 speed, you can use a GM column from a vehicle that had a 700r4 should work. Should retain stock look. The aw4 in XJ's are a good tranny, have overdrive, and are plentiful. Not sure about install, they use a floor shifter, not sure about computer control though. CJ autos never had overdrive put were strong.
Sent from my SM-J320P
I didn't realize the automatic transmissions in cj's onky had 4 gears. No fun on the hwy. I want the original type column shifter and dial as well. . Might have to re think my idea.
4 gears??? now that would be a luxury, the TF999 in mine has a massive 3 gears to make its way through.......
Leave the 5 speed there. If you want an auto jeep with an overdrive you'll have to go newer. Cost to convert yours won't be cheap and the devil is in the details. I'd suggest keeping it original as that's where the value comes from.
What I don't like about the 5 speed is the stiffness of the manual clutch. Does anybody ever put in some sort of power assisted clutch?
My clutch is newer and has been adjusted...
I personally never thought CJ t5 clutches were stiff. Compared to a Honda or Toyota, yeah, they feel stiff. Import clutches tend to feel almost "broken" to me but I daily drove a 5 speed 12 second Mustang for 15 years an drive big CDL trucks now. Some CJ's have hydraulic clutches, instead of mechanical linkage that may be able to be swapped in.
^^ this^^ swap in a hydraulic clutch pedal and you'll be much happier.
