Valve Cover Bolts Won't Stay Tight
joshvt
Scrambler Enthusiast
charlotte
nc
I recently installed an OMIX aluminum valve cover. I used a felpro gasket instead of the cork one and installed dry (no rtv) per the felpro instructions. I torqued the allen bolts to 55in-lbs working from the center out per the instructions. First drive and the thing leaked. It didn't leak near the usual spot in the rear, but instead it leaked near the drivers side front bolt that I had to tap. I checked the torque after the engine cooled off and all of the bolts needed 1/4 to 1/2 turn to get them back to 55in-lbs. I've done this 3 times now. the leak seems to be less severe (it's still there). Last night I torqued them while the engine was still hot- not sure if that will make a difference (haven't had a chance to drive it yet). Is there a trick to getting the bolts to stay tight? I have lock washers on them, but apparently that is not doing the trick. Guessing I might need to replace the gasket now that oil has found a path?
Strange but not unheard of, they should stay torqued in place after the retightening. Last resort would be some thread lock on them or maybe replacing the bolts with new ones, they could be stretched from tightening, doesn’t take much on those 1/4x 20s. If it is leaking in certain spots the cover could be warped and not “true”. I’d take it off and put a straight edge on it and check. Sometimes Omix’s “quality control” is a little suspect.
I replaced mine with the aluminum one also and used the felpro gasket, I read several articles on whether to use rtv or not and found mixed reviews, I used it on the valve cover side in the event that there was minor warpage and haven’t had any leakage problems. I let it sit overnite to cure before installing, also installed with new allen heads, just anal when it comes to things like that. Actually I think you get a better seal on the valve cover side using the rtv with the retorquing taking care of the head side.
Right or wrong just my 2 cents worth.
Hope you get it figured out, nothing worse than an aggravating valve cover leak.
Beautiful jeep weather here in NC today so I found a lot of around town driving to do. Miraculously, the valve cover leak has almost stop. I've still got a trace amount of oil on the cylinder head near the front passenger side screw, but it's waaaaay better than it was. I torqued the bolts again yesterday- it does seem like they need to be torgued a little less each time- just can't believe it's taken this long- I have re-torqued them 5 times now!
Nice in SW Georgia also. That’s good, maybe you got it.
