Bilstein shock tech support phone #
jammer1
Maple Hts.
Oh
I'm installing a 79 cj7 suspension on a cj8 frame and would like to use bilstein shocks. On the front I have the lower shock mount on the spring plate and upper is the higher shock tower. If I remember right full extension is 25". this is longer than the 3 to 4 inch lift shock and their web site doesn't list a longer shock for the cj's. So far I haven't been able to find a tech number, just a headquarters number. Does anyone have the paper work that came with the shocks. It probably has a tech number on it. thanks.
Thank you. I went through their web site and didn't see that page. Hoping to talk to the tech guys to see if they have a shock that would work. If not I'll end up making mounts to use the smaller shock towers.
I'm using the remote reservoir 7100s valved 255/70 on mine. I'm not stock, but have been very happy with the ride improvement over the rs9000s that they replaced.
I needed the remote reservoirs to get the extended and compressed lengths I was looking for, but you might be able to go with the 5100s or non remote reservoir 7100s.
Kyle
It will be interesting to see if your results match their narrative.
