- Suwanee
- GA
So the hose that goes from the power steering pump to the steering box appears to be leaking pretty bad. I believe the rubber hose has cracked right around the fitting where it transitions to the metal piping.
Some PO has replaced the original engine with a Chevy 350. It doesn't appear that the steering pump and steering box are anything but original parts.
So what is the best replacement hose available? How hard is it to remove the existing hose and replace it, including draining the fluid and replacing?
Any advice is greatly appreciated.
