Omix-ADA replacement Speedo cluster. Can odometer be set?
NHScrambler
Chester
NH
I have not been able to find the answer to this question online so I figured I would ask here. The Jeep currently has an aftermarket Speedometer and I am putting it back to a stock dash. I took the Speedo gauge cluster I was going to use for my Scrambler rebuild apart to clean it up and realized the odometer shaft is rusty and frozen solid. I was thinking of going with a Omix ADA replacement speedo cluster but was wondering is there a way to set the odometer to match the original documented mileage?
A drill on the end of a speedo cable? Might burn it up though, just a though.
Not sure about the Omix speedometer, but know the stock odometer can be reset. There's a little bit of a learning curve, at least for me, but it can be set to any mileage you like. Personally, I'd source an OEM speedo rather than going with the Omix- :twocents:1619197062423.png
Not sure about the Omix speedometer odometer, but know the stock odoometer can be reset. There's a little bit of a learning curve, at least for me, but it can be set to any mileage you like. Personally, I'd probably try and source an OEM speedo rather than going with the Omix- :twocents:View attachment 93327
Thanks for the tip! I will have to give that a shot.
I would find a used original- the OMIX are poor quality and the Temp/Fuel are typically unreliable. You can get them warrantied- but taking them in and out is not fun.
As other have said, can reset by hand or a drill.
