Tubing to keep from crushing frame with bolts
ManyFacesofSchwinn
Active member
Silver Member
Rathdrum
ID
Hello,
Anyone know where to buy the tubing sleeves that go through frame to keep the bolts from crushing your frame when you tighten them up? 3/4" Outside Diameter 1/2" Inside Diameter X 2 3/8" long. I need 4 of them. I guess I could buy tubing and make my own but wanted to know if anyone sells them already made up. Thank you. Barry
Could you just use shoulder bolts?
Like the ones used on the front frame horns when adding a winch plate?
A metal shop or welding outfit can help you out. Bring your bolt you intend to use, let em know what you plan to do, they can size the tube ID, then it's total length. Probably would cut the tube to your specified length.
I'm going to a metal shop tomorrow to buy some tubing. I just thought it'd be handy to buy some already cut to size and painted.
I meant something like this. The tubing works as well and probably cheaper / more flexible.
I run a full tube bending fabrication shop and always have drop tubing, bends, etc laying around. Let me know what you need and I would be happy to send you some drop tubing.
Cool! I need four of them with 3/4" OD X 2 3/8" long and four of them 3/4" OD X 3 3/4" long. Let me know what I owe you. If you have paypal I can pay you that way? Thank you very much. Barry
I'll be putting 7/16" bolts through them, so anything over that for the ID is fine.
Barry Gray
15985 W. Nelson Loop Rd.
Rathdrum, Idaho 83858
