2150 Carb swap
Neilth
New member
Sacramento
CA
I need some pics of linkage for a 2150 Motorcraft carb. I have it mounted up. I have some ideas, but any suggestions to make it easier would be appreciated. It is a stock 6 banger 85 vintage.
I used a stock V8 throttle cable from a 1980 CJ7 on mine. Works fine. I've had it that way since about 2003
This.
Otherwise you need to find or fab a longer throttle lever arm and use the pull-down. I walked around the salvage yard and found something that worked, drilled two holes and bolted it onto the MC2100 arm.
