Hydraulic clutch slave
Kitchener
On
Good evening ,
I have a 258 and T176 in my 83 scrambler and
I was wondering if any members have done a Hydraulic clutch swap using Novak slave cylinder .
If so what Novak slave did you use 3/4bore
Or 7/8 bore.
I am using a stock iron duke master cylinder with what I think has 13/16 bore.
Thanks
Yes, the stock clutch master is 13/16" bore. The factory slave is 7/8" bore. Does the Novak setup use the factory clutch fork? If it's longer or shorter than stock that changes things.
Wow. I just looked this up on their sight. Maybe I'm just stupid but they kind of confused me. If it was me, I would get the 3/4" bore. Then you can easily switch to a different ratio if needed. The CJ master is 13/16", the YJ is 11/16". Or you could go right in the middle and get a 3/4" bore Wilwood master like mine.
I ended up going to a Girling 7/8 master cylinder as I had a novak 7/8 slave ,instead of buying a new Novak 3/4 slave
I works pretty good but it seemed way lighter when I had original 4 cylinder engine and factory clutch set up .
I am still considering going to mech set up for my 258
Too light of a clutch pedal feel? That's interesting to hear. Makes me want to do a 3/4 slave with the 13 or 14/16 master.
Sorry for the confusion,no
it was perfect when I had factory 4cylinder T176 set up
Before engine swap to 258 now with 7/8 master and slave it is a heavier pedal feel
I wonder if part of that is attributable to the 258 likely having a bigger, heavier pressure plate with firmer rated fingers and a bigger, heavier clutch disc with firmer rated springs in it.
Yes I agree with that , I loved the 4cylinder pedal feel
I am considering going to a mechanical set up like the 258 came from factory with and swap out pedals and home joint linkage
I was on another forum and the guy was complaining about his clutch master cylinder and I said that the next one I get is going to be a Wilwood. He said he already had the front axel Wilwood brake system. He ended up ordering the Wilwood clutch master from Summit and said he loves that now also. This is his. 5339996D-3A22-4FBF-849D-263D1B401CE0.jpeg
