- Redding
- Ca
I have the weld on frame reinforcing side plates and now need to mount my Warn XD9000i winch.
I bought a Warn 19310 mounting kit and the outer holes that bolt the winch plate to the frame brackets don't line up now that the frame plates created a wider span.
Picture below.
Has anyone dealt with this or know of a good mounting plate that can be drilled? I can widen out the holes but I'm worried that won't leave enough steel to be strong enough in a hard pull. I'm sure I can get some frame brackets made up to fit but if there is a good solution someone figured out, I'd love to hear it!
I did find this generic one but it is too wide and deep: https://www.ruffstuffspecialties.com/R2238.html I can deal with the width, but the depth (front to back) will not work well.
I called Warn and they said they don't have anything else that would work.
Here is a pic of the Warn plate:
Picture below.
