- Herriman
- UT
Hi everyone, looking for a little direction on an issue with my turn signals. I'll try to write as much detail as I can to help diagnose the problem. Electrical and lighting is definitely not my strong point and I appreciate any advice the community has to share, thanks in advance! This is on my 1984 CJ8.
I noticed my signal switch felt spongy when I was trying to signal left and also noticed the left flasher wasn't operating. I went ahead and replaced the signal switch and harness inside the steering column. That fixed the spongy feeling because the old worn out plastic switch had cracked. However the left blinker still wasn't working.
I had been planning to swap out the old light for LEDs anyway so I decided now would be good time to do that and possible rule out the blinker issue at the same time. I also replaced the OEM flasher for a unit that is LED compatible. Things are still weird and not working. Here are my notes on what is and isn't working:
- Signal left. All lights blink including both arrow indicators on my dash, just like I had switched on my hazzards. I noticed if I turn the headlights on, everything still blinks except for the front right blinker directly under the headlight.
- Signal right. The front right blinkers flash, but both rear lights flash.
- Sometimes, when I turn on the headlights, the right dash arrow indicator illuminates.
- Noticed when the vehicle isn't running or in ACC position, if I press the brake pedal both rear light illuminate as they should. However, the right arrow indicator on the dash lights up and the front right blinkers illuminate.
I know this is a lot of information, please let me know if anyone has any ideas! Thanks again!
